Six Wires For One Light Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 12:02 PM   #1
Rewards Points: 578
Six Wires for one light fixture?
i cant get a picture of this, so i understand if you cant answer. Im just really curious.
At my future husband's house, the overhead light in his bedroom has fallen and is hanging by the wires. They shut off the power to his room so that its not a fire hazard, but now that the wires are exposed, i can see that there are six wires going into that fixture.Why?
There are three blacks, two whites, and a red. the three blacks are crimped together, the two whites are connected to the white on the fixture, and the red is connected to the black on the fixture. This confuses me. This fixture is the end of a series and does not jump to anything else. There is only one switch.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 01-21-2013, 12:06 PM   #2
Licensed electrician
Rewards Points: 1,008
This is in the middle of the circuit. You have power coming in and also going on to other parts downstream. The red is the switched hot.
Old 01-21-2013, 12:22 PM   #3
Rewards Points: 578
i dont know what else it would be going to, its at the end of the trailer and disconnecting power from it does not cause anything else to not work. Unless they put the receptacles on the same circuit, and i didnt think that was legal?
Old 01-21-2013, 12:36 PM   #4
Unless the HUD code is different, the receptacles commonly share the same circuit as lighting.
Light Fixture With Multiple Wires Hippy007 Electrical 5 11-01-2012 01:54 AM
Can you use wire nuts on a fan light switch with silvery looking wires? amodoko Electrical 4 10-28-2012 09:26 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 01:23 AM
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 07:13 PM
