Single Wall Oven 3 Or 4 Wire Rough-in - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 02:05 PM   #1
crankcase's Avatar
Single wall oven 3 or 4 wire rough-in
We had our cabinets built with an opening to allow a future single wall oven. Just remove doors and shelves for the oven RO. The Cadillac of single convection wall ovens that we would use pulls 22.6A at 240V. So I am roughing in a 30A circuit. I'm using Smurf ENT and pulling seperate conductors. Is a wall oven similar to freestanding range and require 4 conductors? Also would a #14 ground be sufficient? thanks pros.
crankcase is offline   Reply With Quote
Old 03-03-2013, 02:12 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Ground would need to be #10 CU for a 30A circuit. As for 3/4 wire...there would be no way to tell you without the specs or model.
Old 03-03-2013, 02:32 PM   #3
crankcase's Avatar
Thanks kbuz, I wasn't sure if there was a standard. This would be our first wall oven. I found the installation manual off the Whirlpool website and it looks like a 4 wire. Looking at the Whirlpool Gold true convection WOS92EC7AB
Old 03-03-2013, 03:13 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
Typically if the oven is 240 VAC only, it takes a 3 wire circuit (2 hots and a ground).
If it is 120/240 VAC, it takes a 4 wire circuit (2 hots, a neutral and a ground).
You can always future proof the installation and run the neutral even if you do not require it for the current installation.
Coastal South Carolina
Old 03-03-2013, 03:30 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Pull four wires and you wont have to worry about it.
The Following User Says Thank You to stickboy1375 For This Useful Post:
J. V. (03-04-2013)
Old 03-03-2013, 03:43 PM   #6
Idiot Emeritus
Rewards Points: 1,492
I agree, pull all 4 wires, even if you need only 3.
You can always cap off the neutral if it's not needed and if it sits there for the next 100 years, who cares? But if you pull only 3 wires, and when the oven is replaced, the new one needs 4, that's trouble.
Even worse, if the new oven needs 4 wires and there's only 3, most handyman types (and sadly, a lot of pros) will simply use the ground for the neutral also. That's unsafe.
Rob
micromind is offline   Reply With Quote
Old 03-03-2013, 03:49 PM   #7
crankcase's Avatar
good point
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Double wall oven with 4 wire, grounded conductor traxman Electrical 4 05-02-2011 09:31 PM
single wall convection oven wire and braker cgipson Appliances 0 02-22-2011 09:32 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
