Single Vs Double Pole For 240v - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 08:02 AM   #1
single vs double pole for 240v
I recently installed two 240v baseboard heaters in series with one double-pole wall thermostat and it works fine. I saw a 240v baseboard today on ebay that says it works off of a single pole thermostat. Could that be a mistake? Thanks very much.
kentannenbaum is offline   Reply With Quote
Old 12-20-2010, 08:05 AM   #2
joed's Avatar
Rewards Points: 12,442
NO mistake. They will work fine the thermostat will not have a OFF postions. The heater will always have power to it on one of the hots.
Old 12-20-2010, 08:11 AM   #3
Sorry, I don't get it. There are two hots and no neutral running through my existing installed TS. For the new installation, are you saying that if I use a single pole TS, one of the hots just runs directly to the heater?
Old 12-20-2010, 08:11 AM   #4
Also, if you're right, how do you turn power off?
Old 12-20-2010, 09:01 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,066
Ayuh,... At the Circuit Breaker, as Always...
Bondo is online now   Reply With Quote
Old 12-20-2010, 09:12 AM   #6
Actually, may not seem it, but I do understand that. Okay then, one thing: now this does say I'm not fully knowledgeable...
If the 240v heater sales info says it takes a single pole TM, can I nevertheless use a double-pole TM instead? Again, thanks.
Old 12-20-2010, 10:06 AM   #7
joed's Avatar
YOu only need to cut power to one line to stop the heater from heating. Of course there is still power at the heater. If you are going to work on the unit you need to shut off the breaker. You can use a double pole stat if you wish.
Old 12-20-2010, 10:21 AM   #8
Thanks, much obliged
Old 12-20-2010, 03:38 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
In a typical double-pole T-stat there are two micro switches. One is temperature controlled, the other is just an on-off switch which only opens when the t-stat is turned all the way down to "off".
A single-pole t-stat is the same thing without the "on/off" micro switch.
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 02:44 PM
Understanding Circuit Pannel and Single Pole vs. Double Pole circuit brakers grisha_1 Electrical 4 01-31-2009 07:40 AM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
