Old 12-11-2011, 10:23 PM   #1
Single Switch 6 wires?
I just purchased a house built in 1978, I noticed the garage light was on constantly, when I went to turn off the light there was no light switch. In the garage where the switch should be, there is a switch plate cover. I removed the cover and found 3 black wires connected together with a wire nut and 3 white wires connected together with a wire nut. Why are their 6 different wires and how do I wire a single switch to be able to turn off the garage light? Many thanks for any assistance!
Mikemonica is offline   Reply With Quote
Old 12-11-2011, 10:42 PM   #2
retired elect/hvac/plumb
plummen's Avatar
id figure out which black wire goes only to garage light and seperate it from other 2 wires.
then i would pigtail the other 2 blacks with another piece of wire and hook it to one side of a light switch,then hook black wire from light to other side of switch
plummen is offline   Reply With Quote
Old 12-11-2011, 10:45 PM   #3
All 3 black wires to the switch? Do nothing with the 3 white wires?
Old 12-11-2011, 10:54 PM   #4
plummen's Avatar
yes the white wires are neutral wires,tuck them back into box out of the way of switch
The Following User Says Thank You to plummen For This Useful Post:
Mikemonica (12-11-2011)
Both wires in switch are black Manshri Electrical 3 02-06-2011 08:47 AM
light switch with 2 hot wires srmusaf Electrical 21 12-07-2010 06:26 PM
single light switch with 3 14-2 wires Larry Penny Electrical 2 08-26-2010 05:13 PM
Need Help Troubleshooting 3-way + Single Pole Switch Install OmegaRed1723 Electrical 6 10-09-2009 11:25 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
