Single Pole With White On The Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2008, 07:13 PM   #1
Single pole with white on the switch
Hey everyone, i searched for this but didn't find a definite answer.
I am replacing a bathroom fan, in the process of wiring at the fan with the switch off I got shocked , so i turned off the power at the panel and wired it up, the fan works fine. Obviously i thought i was safe with the switch off. Anyway, looking at the switch my white wire from the panel is on the bottom of the switch and the white from the fan is on the top, the black is straight connected and not switched.
My basic understanding is that the black should be the hot wire and if so even with the switch off the fixture would still have power and i likely shocked myself by completing a circuit with the ground wire. Does this sound like the problem?
Also should i switch this around so the black wire is switched and not the white? i dont think anything else is on this circuit, but im not 100% sure.
I hate screaming like a little school girl.
grog is offline   Reply With Quote
Old 08-10-2008, 07:21 PM   #2
Master Electrician
JohnJ0906's Avatar
If (big IF) the wires are used correctly, then, yes, the blacks should be switched, and the whites wired through.
Do you have a voltage tester? If so, with the switch on, check the voltage from black to ground, and the white to ground. If the readings are 120 volts (or so) from black to ground, and 0 volts from white to ground, the switch is wired incorrectly.
You have discovered why we wire switches by controlling the hot, not the neutral (return). It works either way, but leaves power at the controlled device when the switch is off.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-10-2008, 07:26 PM   #3
i have done that and exactly as you said i get 120 between the black and the ground nothing between the white and the ground. I was wondering if i had a hot ground wire at first but i tested the wires off the switch with one of those circuit testers with the three lights, it indicated no problems.
so i wonder should i rewire the switch, i guess its "safe" as long as you dont try to work on it with only the switch off.
Old 08-10-2008, 07:36 PM   #4
checked again and for sure i get 120 black to ground, but i get 0.1v between white and ground, im not sure if that means anything.
Old 08-10-2008, 07:56 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes I agree with that.
Yes....It means they are switching the neutral after the light (load). Big NO NO !!
Take the whites off and put them into a wire nut. Then take the blacks apart and connect them to each screw on the switch.
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 06:13 PM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Anybody ever seen a 5A 250V single pole switch? jayp Electrical 5 08-04-2008 05:41 AM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 07:06 PM
