Old 10-24-2008, 11:49 AM   #1
Single Pole vs. Double Pole Thermostat
Folks,
Doing a remodel for a customer and ran into a new situation. Some background, the whole house has the Cadet heaters in each room. In all but one of the rooms, there is a single pole thermostat ( it doesn't turn all the way off, they just have a very low setting). My question concerns the what used to be the attached garage. When the house was built there were two cadet heaters wired together to a double pole thermostat in the attached garage. After an earlier remodel turning this garage into living space, one of the heaters was disconnected (at the heater) so what was left was one heater, in a bedroom, that is attached to a double pole thermostat.... which appears to have failed because as soon as the double pole thermostat is turned on, the heater runs and does not shut off.
They want me to make this heater work like the heaters in the rest of the house - that being, they want a single pole thermostat on this cadet heater. It is the only heater on that circuit.
So, my questions are:
1). Are the heaters connected to a single pole vs. double pole different types of heaters, or should I just be able to install a single pole thermostat on this heater?
2). While I'm doing this work, they would like to the change all their "manual" type thermostats to an electronic version - without breaking the bank. I've looked at the big box stores and they appear to be around $50 or so a piece for a low end unit. Are there any recommendations you could guide be towards or away from?
Thanks in advance........
dforeid is offline   Reply With Quote
Old 10-24-2008, 09:01 PM   #2
Any ideas???
Old 11-26-2008, 06:24 PM   #3
Electrical Contractor
kbsparky's Avatar
Double pole line voltage thermostats have an "off" position, which can also act as a disconnecting means for your heater units.
Single pole stats do not, and cannot be turned "off" but only "down"
You can use either to control individual heating units in your house.
Old 11-26-2008, 06:40 PM   #4
Advice worth 2 cents!
hey KB! 40 years in this business and I still didn't know why the two types existed or the difference between the two! I only do industrial and have a really limited knowledge on residential. (which I only do in my own home)
So, thanks
---pete
HandyPete is offline   Reply With Quote
Old 11-26-2008, 06:47 PM   #5
So, thanks
I was just thinking that. What's the advantage in opening one leg vs. both? The only disconnecting means I would trust if working on the heaters would be the breakers.
jerryh3 is offline   Reply With Quote
Old 11-26-2008, 10:57 PM   #6
kbsparky's Avatar
There are some cases where the circuit breaker is not readily accessible (such as in certain multi-family units, or hotels, etc) and the use of a DPST thermostat satisfies the disconnect requirements of 424.19.
It is interesting to note that most double-pole thermostats only interrupt one pole of the circuit during its normal mode of operation.
Turning it all the way down to "off" is the only way to interrupt both circuit conductors in most cases.
IF you want to use a DPST thermostat in a single pole configuration, then you have to wire both poles in series, to ensure proper interruption of the circuit when the desired temperature is reached. Otherwise, the heater may operate continuously even after the set point has been reached.
Old 08-25-2012, 09:31 AM   #7
Question
I have been considering this DPST vs SPST dilemma for a while. In my home I have ONE room which would require a DPST thermostat since it has two heating runs (radiant ceiling) in the plaster. The rest of the rooms are SPST. Here is what I have:
I have a BUNCH of new Honeywell programmable thermostats. Their wiring diagram is as such:
Is there any way I can safely & to code wire these units into the existing boxes (shown above)?
Thanks for any help. I desperately need to save $$$ this year.
Papa Smoke is offline   Reply With Quote
Old 08-25-2012, 09:40 AM   #8
Lic Electrical Inspector
electures's Avatar
WHat are the specs on the t-stat? Is it rated for 240V?
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 08-25-2012, 11:06 AM   #9
Power supply: 240/208 VAC 50/60 Hz
Max load 15.0 A (3600 W @ 240V, 3120 W @ 208V)
The breakers are all double.
Old 08-25-2012, 12:23 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
You have to pull the spliced whites out of the box and separate them. Cap everything off, turn on the breaker and test to see what pair is your 240v LINE. Turn them off again and install your thermostat according to the instructions.
In your pic they are using a SP t-stat for a 240v load like they discussed long ago earlier in this thread.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Papa Smoke (08-25-2012)
Old 08-25-2012, 12:25 PM   #11
The number of heaters on the circuit is irrelevant. Other factors determine if a SP or DP can or should be used.
Old 08-25-2012, 01:20 PM   #12
Turning it all the way down to "off" is the only way to interrupt both circuit conductors in most cases.s:
This is because the two poles do not always turn on together at the same temperature or turn off together at the same temperature.
Occasionally a double pole line voltage thermostat is found controling one side of each of two heater feeds because they are on different branch circuits or the total heater wattage exceeds the wattage rating of one switch pole.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-25-2012, 03:17 PM   #13
Speedy Petey -
I tried wiring THIS way:
and get nothing.
You have to look at the drawing a bit on the close side but it can be made out.
On both sides of the word POWER, I have labeled the wires coming from the breaker as 240V Black & 240V white. (They ARE 240V). I ran them to the two INNER wires of the t-stat...black to black & white to red.
I then ran the two load (outer) wires from the T-stat to the LOAD wires going to the ceiling heat. Black to black & red to white.
I do get power but the t-stat does nothing. It didn't spark or turn on.
Thoughts?
Old 08-25-2012, 07:54 PM   #14
Speedy Petey -
Attachment 56280
and get nothing.
Thoughts?
Do you get 240 volts between the two load wires when the thermostat knob is turned all the way clockwise, and zero volts between the two load wires when the knob is turned all the way counterclockwise?
Old 08-26-2012, 09:12 AM   #15
Yes. It does just that.
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 10:20 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 09:25 PM
