Old 07-20-2008, 11:16 PM   #1
single pole vs. double pole circuits
i am wiring a new water heater that calls for 4 40 amp or 2 75 amp circuits. Am i able to use single pole 40 amp circuits with #8 wire, or do I need to use double pole 40. I dont want to use the 75 amp due to the #4 wire I would have to use, and I dont want to use 8 slots in my box for the 4 double pole 40s. What do I do?
Thanks,
DannoW
DannoW is offline   Reply With Quote
Old 07-20-2008, 11:59 PM   #2
Cow
Pick one, those are your choices.
Cow is offline   Reply With Quote
Old 07-21-2008, 12:01 AM   #3
Electrician's Helper
Pudge565's Avatar
Send a message via AIM to Pudge565
what does the owners manule say? By what you describe I take it that this is an ondemand water heater? If so from what I read on here in other threads that you need at least a 200 amp service for those. But back to your question I think it would need double pole breakers.
Pudge565 is offline   Reply With Quote
Old 07-21-2008, 12:14 AM   #4
" Euro " electrician
frenchelectrican's Avatar
What model number of this tankless waterheater is ??
and are you in USA or Canada ? there is two diffrent codes on this one.
Merci,Marc
Old 07-21-2008, 07:03 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
What do I do?
Thanks,
DannoW
Get rid of that #$%&* tankless electric water heater!
Don't dealers of these things go over this stuff before hand to let folks know what a hassle it can be???
Oh yeah, duh, they might not make the sale that way.
Old 07-21-2008, 07:13 AM   #6
nap
You talking to me?
nap's Avatar
the theory of these things is great.
that is where things end from what I see. The power requirements, either electrical or gas, often require such major work, the installation costs a fortune. On top of that, it seems they are not all they are cracked up to be. Too many folks either not setting then correctly, not understaning their limitations, or not buying a large enough unit.
Old 07-21-2008, 09:36 AM   #7
Power Gen/RS Engineer
I think that this is the biggest problem.
I considered installing a natural gas unit. No picnic!
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 07-21-2008, 10:20 AM   #8
Somehow what.,, the Gaz fired units seems better than electric unit due the BTU rating and yeah of course you will hit the snag with gas system you will probly a good chance need to upgrade the pipeing system and Of course the gaz metering device it will have up upsized anyway.
Merci,Marc
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
40 amp double pole gfci problem rivers Electrical 38 07-19-2008 01:10 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
Slimline Vs. Tandem Vs. Double Pole turd hurder Electrical 1 06-23-2008 04:00 AM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 09:25 PM
