Single Pole Switch Wired With Two Neutrals. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 03:08 PM   #1
buckybadger's Avatar
Rewards Points: 85
Question
Single pole switch wired with two neutrals.
I went to replace a single pole light switch with a new occupancy sensor switch. 14-2 coming in to the switch and 14-2 going out to the light fixture. Basically the switch was wired in reverse of what you would expect. The two neutrals were on the switch and the hots were capped off together. I can be fairly certain that the neutrals aren't masquerading as hots because I went to the junction box on each side of the romex and all the neutrals and hots are capped off together.
The obvious danger would be going to change out the light bulb with the switch "off" and getting popped.
Any other ramifications for flipping the hot/neutral on a single pole?
(By the way I have rectified the situation. Sometimes peeling back the layers on an old house is like peeling an onion; the deeper you go the more it stinks).
buckybadger is offline   Reply With Quote
Old 07-25-2012, 04:12 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,990
It's definitely against code. There are no other issues I'm aware of aside from the hazard of the socket remaining hot regardless of the state of the switch.
mpoulton is offline   Reply With Quote
Old 07-26-2012, 07:04 AM   #3
Just flip the wires at the switch. Tie neutral and control hot.
austinbblock is offline   Reply With Quote
single pole switch with pilot light tsc2011 Electrical 8 11-29-2011 07:50 AM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Problem with 230 volt double pole single throw switch rdempsey Electrical 6 06-23-2011 09:51 AM
How do I provide power to a plug when changing single pole 3 wire to 3-way switch Morris12 Electrical 4 01-05-2011 08:41 PM
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 08:51 PM
