Single Pole Switch With Pilot Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 06:59 PM   #1
single pole switch with pilot light
I have a white and a black in the box and am trying to hook up a single pole switch with pilot light. I've tried a few combinations but either just the switch works or just the pilot light works. How do I wire it so the pilot light comes on when the switch is on?
tsc2011 is offline   Reply With Quote
Old 11-28-2011, 07:04 PM   #2
Electrician
Rewards Points: 794
Sounds like you have a switch loop in the box, you will need to get the neutral from the circuit down in the box for the pilot light to work.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
tsc2011 (11-28-2011)
Old 11-28-2011, 07:48 PM   #3
Rewards Points: 115
am I correct to say the pilot light would not work if just a switch loop? there is still no neutral
pokey is offline   Reply With Quote
Old 11-28-2011, 10:35 PM   #4
Electrician
Rewards Points: 794
Lights always need a neutral to work.
Old 11-29-2011, 12:54 AM   #5
wouldn't it work if the pilot was wired in series with the switch?
Old 11-29-2011, 01:09 AM   #6
biggles's Avatar
the switch is breaking the hot to the load the light is hot also but you need to land a neutral
Old 11-29-2011, 05:31 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
The pilot light is a high resistance compared to the other devices....if you put it in series, good chance nothing lights up.
As noted above....you need a neutral.
Old 11-29-2011, 06:26 AM   #8
Rewards Points: 1,512
No.
(Almost always) the pilot light will go on with the switch but the light or fan or whatever you are using the switch for will not.
The night light feature of a switch connects the little switch light in parallel with the switch (and that combo is in series with the fan or light or whatever being switch controlled). With the switch turned off, (usually) enough current flows through the night light to light that up but not run the fan, etc.
Some switches with lights inside can be wired up either as pilot light or night light. For the pilot light mode a neutral is needed in the switch box.
Old 11-29-2011, 07:50 AM   #9
joed's Avatar
Rewards Points: 12,862
There is a big difference bewteen a lighted switch and switch with a pilot light. The lighted switch has the light, usually neon, in parallel with the switch. It lights by running a trickle current through the load when off. This is why CFL lamps will flicker on lighted switch.
Re-wire dual pole switch to single pole bujaman Electrical 3 05-31-2011 06:09 AM
2 way dimmer & 3 way switch paulegan25 Electrical 14 11-22-2010 12:37 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Need Help Troubleshooting 3-way + Single Pole Switch Install OmegaRed1723 Electrical 6 10-09-2009 10:25 PM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
