Old 09-19-2009, 11:58 AM   #1
single pole switch for jacuzzi tub
I am trying to use a switch to power my jacuzzi tub. It is older and does not have any buttons on the tub itself. I found a diagram on-line and tried that but I am having problems still. Here is what I did. I went green from motor to green screw on GFCI, white from motor to white on GFCI and black from motor to a screw on a single pole switch and black from GFCI to the othe screw on single pole switch. Still getting constant power.
Could it be possible the switch is defective?
kodeblue is offline   Reply With Quote
Old 09-19-2009, 12:21 PM   #2
Household Handyman
You probably have a two-way switch, (not a "single pole" switch), whereas the toggle when down is "OFF" and when up is "ON", and is so labeled. Possible the switch is bad, turn off the power, remove the switch, and test with a multi-meter to determine if it is bad or not. Why wire the motor through the GFCI to begin with? Are you using the GFCI as protection? Not a good idea to me. Having the GFCI there will be tempting to use for another reason, IMO--each trip reduces the life of the GFCI. IF the motor will run with just the switch, seek an alternative method of ground-fault protection. Are you sure the motor will run-safely? Good Luck, David
Old 09-19-2009, 12:21 PM   #3
J. V.'s Avatar
Sure it could. Your wiring description sounds right. How are you doing this? Are you feeding a GFCI receptacle and then feeding the motor with the load side of the GFCI with the switch breaking the black (hot)? Is that correct?
Old 09-19-2009, 12:29 PM   #4
That is exactly how I am doing it. I am using a GFCI as a ground fault because nothing else will be used on it.
Old 09-19-2009, 12:33 PM   #5
The one on the left is the same as mine.http://www.sscnet.ucla.edu/geog/gess...-household.jpg
Old 09-19-2009, 12:42 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
This whole thing scares me. Are you sure you know what you are doing?
Where is the circuit ground if you are going from the motor to the GFI?
How are you feeding the GFI?
What you describe does not tell us where the feed is.
You do realize this is a tub here? This is a potentially lethal setup if done wrong.
Old 09-19-2009, 12:48 PM   #7
I do understand it is dangerous and will be having it inspected when the work is all done and before it gets used. The ground from the motor goes to the green screen on the GFCI. Here is how I have it setup. http://www.terrylove.com/jet.htm
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 11:10 AM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 03:44 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
