Single Pole - Load Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 02:46 PM   #1
Single Pole - Load wire?
Hi... I am trying to install a ge single-pole timer which has 3 wires. Hot, Neutral, and Load. My problem is my switch only has 2 wires... What exactly do I do with the load wire? Thank you for any info
Last edited by sillyrope; 12-17-2010 at 06:41 PM. Reason: correct outlet to switch
sillyrope is offline   Reply With Quote
Old 12-17-2010, 02:51 PM   #2
Licensed electrician
Rewards Points: 1,622
Timers typically replace switches, not outlets.
What wires are in the box and is this a switch or a receptacle?
Old 12-17-2010, 02:52 PM   #3
it's a switch which was powering a circular cfl but I decided to replace it with a regular cfl and change the switch to a timer.
Inside the switch is 4 wires. 1 white 1black on top and 1 white 1 black on bottom.
A pigtail has been covering a black/white. so I have one black and white.
The timer has 3 wires. The load wire being red.
Old 12-17-2010, 04:38 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
This sounds like a 4 way switch.
Can this light be operated from more than one location?
Old 12-17-2010, 04:48 PM   #5
I thought it sounded like a single pole with two romex cables in the junction box (which oughta be faily straightforward if that's the case). How many terminals are on the original switch? I think the terms "switch" and "junction/outlet box" have been used interchangeably.
clashley is offline   Reply With Quote
Old 12-17-2010, 06:31 PM   #6
this switch only lights up the hallway light as far as I know. I'll post some pictures when I try again as I went back to the old switch. I called jasco but it may seem the house may be too old, built before 1970 to have a load wire.
Old 12-17-2010, 09:45 PM   #7
I=E/R
a7ecorsair's Avatar
How many screw terminals are on the switch 2, 3,or 4?
What is connected to each screw?
Now, just so you understand what you are hooking up:
The time needs power to operate - I'm not talking about turning on the lite, I'm talking about power to actually run. This means the timer needs a hot and a neutral. To turn on the light, the timer will connect the hot to the load and send power to the light. The light has to have a neutral connection too.
We need to better understand the old switch wiring so a picture would be nice.
a7ecorsair is offline   Reply With Quote
Old 12-18-2010, 12:06 PM   #8
Rewards Points: 459
You probably don't have a neutral ran to the switch. It's not uncommon to find power ran to the light, down to the switch & back up, with no neutral being necessary...
The timer needs a neutral in order to complete the circuit to power itself. You'll need a way to shoot a neutral to it.
Can you fish a wire through the wall from a basement or crawlspace?
Nick DIY is offline   Reply With Quote
Old 12-18-2010, 12:10 PM   #9
joed's Avatar
Rewards Points: 12,904
You have a switch loop. There is no neutral wire even though there is a white wire. You must find a timer that dos not use a neutral wire and is OK for CFLs.
Tags
load wire
Single Pole Breaker VS. Quad Breaker Livewire78 Electrical 37 11-28-2012 08:26 AM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 06:41 PM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 02:44 PM
