Single Pole Illuminated Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 09:09 PM   #1
Rewards Points: 208
when you go from a flip switch to those decora illuminated light switch, do you keep the orientation (top or bottom) of the black wires the same?
Scully is offline   Reply With Quote
Old 12-19-2011, 09:15 PM   #2
Mad Scientist
Unless the new switches have terminals specifically marked LINE and LOAD, it shouldn't matter.
McSteve is offline   Reply With Quote
Old 12-19-2011, 09:18 PM   #3
Rewards Points: 208
McSteve, it's the leviton model. so if you switch the black wires, the switch and orange LED will still work?
http://www.amazon.com/Leviton-104-05...4351024&sr=8-1
Old 12-19-2011, 09:27 PM   #4
Mad Scientist
Correct. On that switch, either wire can be on either terminal.
And just so you know, if you use CFL bulbs, they may not work properly with that switch, they might flicker occasionally when the switch is off.
Old 12-19-2011, 09:40 PM   #5
Rewards Points: 208
so regardless of how the black wires are connected to either terminal, the orange led will always turn on when switch is off?
also, i see some switches wrapped in electrical tape...is that always necessary?
Old 12-19-2011, 09:41 PM   #6
Mad Scientist
Correct. And no, the tape isn't necessary.
single pole light switch bamadad33 Electrical 4 02-04-2011 08:59 PM
2 way dimmer & 3 way switch paulegan25 Electrical 14 11-22-2010 12:37 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
