-   -   Single Pole Illuminated Light Switch (http://www.diychatroom.com/f18/single-pole-illuminated-light-switch-127125/)
Scully 12-19-2011 09:09 PM
when you go from a flip switch to those decora illuminated light switch, do you keep the orientation (top or bottom) of the black wires the same?
McSteve 12-19-2011 09:15 PM
Unless the new switches have terminals specifically marked LINE and LOAD, it shouldn't matter.
Scully 12-19-2011 09:18 PM
McSteve, it's the leviton model. so if you switch the black wires, the switch and orange LED will still work?
http://www.amazon.com/Leviton-104-05...4351024&sr=8-1
McSteve 12-19-2011 09:27 PM
Correct. On that switch, either wire can be on either terminal.
And just so you know, if you use CFL bulbs, they may not work properly with that switch, they might flicker occasionally when the switch is off.
Scully 12-19-2011 09:40 PM
so regardless of how the black wires are connected to either terminal, the orange led will always turn on when switch is off?
also, i see some switches wrapped in electrical tape...is that always necessary?
McSteve 12-19-2011 09:41 PM
Correct. And no, the tape isn't necessary.
