Single Pole Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 09:22 PM   #1
Rewards Points: 174
Single Pole Dimmer
Hey Guys,
Recently replaced the light in my sons room and figured I would add a dimmer/switch combo unit while I was at it.... My current single switch must be achent as it only has two terminal screws. Black is on the top right, White is on the bottom left.... Ironacally white is hot -
Now my dimmer/switch has two black and a ground, obvisoly I know what to do with the ground but can't for the life of me get this working any ideas? pics below....
Single Pole Dimmer-img00001-20100605-2029.jpg   Single Pole Dimmer-img00002-20100605-2029.jpg   Single Pole Dimmer-img00003-20100605-2029.jpg
tb582 is offline   Reply With Quote
Old 06-05-2010, 10:40 PM   #2
Electrical Contractor
kbsparky's Avatar
You are dealing with what is commonly known as a 2-wire switch loop.
The white wire feeds the power down from the light, and the black wire feeds switched power back to control the light.
The 2 black wires on your dimmer connect: One to the white, the other to the black (doesn't matter which one to which).
When you replaced the light in the ceiling, did you change any of the wiring in that outlet box?
-KB
Old 06-06-2010, 08:59 AM   #3
Rewards Points: 174
nope, simply replaced the old light with the new
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 10:20 AM
