Single-pole 220V Switching - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 05:42 PM   #1
I bought a themostat for a new 220V baseboard heater. The thermostat is from Honeywell as is the heater, and noted "110V or 220V." I am curious how it breaks only one hot leg, and not both. (thus, single-pole)
Doesn't this leave one hot, unswitched wire at the appliance? Why wouldn't the heater work with the one hot, unswitched leg?
BergquistC is offline   Reply With Quote
Old 12-30-2008, 05:46 PM   #2
Licensed Pro
It does leave an unswitched hot, but it interrupts the other hot leg so the 240V circuit is not complete.
Old 12-31-2008, 12:50 PM   #3
Rewards Points: 246
And yes, you can get shocked if you open the heater connection box without turning off the breaker. One leg will always be hot at the heater.
A 240 volt appliance needs both wires to complete the circuit. The thermostat only opens one wire. It is due to the manufacturer that made the T-Stat. It's much cheaper to build with one contact than with two.
J. V. is online now   Reply With Quote
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 08:12 AM
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 06:13 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 09:20 AM
