Old 11-01-2007, 07:13 AM   #1
Single outlet
The "auxiliary" outlet near my hot air furnace is a single outlet in a 4" square box. Is that some kind of code requirement? Can I just replace that box with a deep 4" and put two duplex outlets in there?
Thanks.
rkhpapa is offline   Reply With Quote
Old 11-01-2007, 11:24 AM   #2
Single outlet
The way to find out is to call your local building authority. You might or might not need a dedicated circuit for whatever this outlet is for. Do you know what the outlet was put there for?
Old 11-01-2007, 12:25 PM   #3
Single outlet
I was just about to post a similar question....
Does the furnace need to be on a separate circuit or can power be run from a nearby outlet?
moneymgmt is offline   Reply With Quote
Old 11-01-2007, 12:45 PM   #4
47_47's Avatar
Single outlet
Good question. Every house I owned did have it on a seperate circuit, with a disconnect (on/off) switch near it though. I do know that sump pumps must be on their own.
47_47 is offline   Reply With Quote
Old 11-01-2007, 01:35 PM   #5
J. V.'s Avatar
Single outlet
What do you mean by "auxiliary" outlet? If it is part of the furnace you just need to ask the manufacturer.
Old 11-01-2007, 03:09 PM   #6
Electrician philosopher
Single outlet
I bet a dollar it is on a single outlet because it is in a basement. The original electrician installed a single recp. to avoid putting in a GFCI. If you replaced the single recp. with two duplexes and I am in fact correct in my assumptions, then you would have to protect this circuit with a GFCI.
Interestingly enough, In 2008 NEC the rules change for basements and garages, with the elemination of the exception for single recps on normally protected circuits. Now how big a nerd am I for already having my '08 codebook when GA won't adopt until '09??
Andy in ATL is offline   Reply With Quote
Old 11-04-2007, 07:49 AM   #7
Single outlet
Thanks for the responses, guys. I took the time to follow the romex back to the box. The furnace itself is hardwired on an individual circuit. The outlet I was talking about is one of two that is run off another circuit that provides current for the humidifier motor, evaporator pump, etc. I can't see any good reason why it wasn't a duplex, though. I guess my question stands. The GFI answer was a good one, but there's already two outlets on the run. If you're gonna put an outlet there, and everything is low current, why just a single receptacle and not a duplex?
Old 11-04-2007, 08:07 AM   #8
Electrician
Single outlet
What code requires this?
chris75 is offline   Reply With Quote
Old 11-04-2007, 08:12 AM   #9
Electrician
Single outlet
Maybe thats all the guy had on his truck... sometimes you have to use what you have on your truck.
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
