Single Gang Box Used As A Junction? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 07:53 PM   #1
What can I find here?
Winchester's Avatar
Rewards Points: 150
3-Way Dimmer Circuit w/ questions
I currently have a regular light switch for our dining room table that I feel was placed in a poor position.
Similarly in an adjacent room, the light switch for our four seasons room was poorly placed around the corner. In other words, it's not in the room for which it's being used. Where it should be located, is a switch for an outdoor light. I cannot place a 2 gang box here because of the wall construction (lack of room) but will place a double switch most commonly found in bathrooms with vent & light combinations.
Back to the dining room light. I've just recently installed a new chandelier and it desperately needs a dimmer. I already had in my possession a set of 3-way switches that include dimmers that I would like to install. The original location of the four seasons room light switch will now house one of the 3-way switches. While on the opposite side of the room I'd like to install the other 3-way.
This long explanation takes me to my question. Can the single gang box from which I'd like to remove the original chandelier switch be covered, made to be a junction box, and drywalled over like it was never there?
This is my first question asked on this forum.
Much thanks in advance.
Winchester is offline   Reply With Quote
Old 09-01-2008, 08:13 PM   #2
Rewards Points: 506
Send a message via AIM to theatretch85
This would be a big NO. You can use it as a junction box, but it MUST remain accessible. That is you can put a blank cover over it but you cannot drywall over it. If you can move the wires to the new box and eliminate the old box entirely then that would be your better option. Otherwise you could run longer wire between the source and the fixture or relocate the junction box to say maybe the attic?
theatretch85 is offline   Reply With Quote
Old 09-01-2008, 09:54 PM   #3
Winchester's Avatar
Rewards Points: 150
Thank you for your answer. I was afraid of this but your answer also led me to a more accurate troubleshooting of the existing wiring scheme.
Old 09-01-2008, 10:31 PM   #4
Winchester's Avatar
Rewards Points: 150
Correct Circuit?
#1 is my source
#2 is the current switch for which I wish to remove.
#3 would be my master 3-way switch
#4 is the switch for the 4-season room light for which will be moved and the slave 3-way switch inserted.
Red path is the existing circuit for which I wish to remove.
Blue path to the master 3-way
Yellow path to the slave 3-way
Green path to the chandelier
Would this be the proper method for installing this circuit? Correct me if I'm wrong, but the yellow line would be my only 3-wire?
Any help appreciated.
Old 09-01-2008, 10:57 PM   #5
Rewards Points: 506
#1 is my source
Looks good, if you want to remove that existing box I would look at going down to that outlet box from the ceiling. Is there an attic above this room or an open basement below? How do you plan on wiring the blue and green paths?
The yellow path would be your only 3 wire circuit.
Old 09-01-2008, 11:10 PM   #6
Winchester's Avatar
Rewards Points: 150
Thanks for your reply again.
I have an unfinished basement below. Above is the second story.
Old 09-01-2008, 11:29 PM   #7
Rewards Points: 506
Hmm, that will make it difficult to remove that existing box. My suggestion would be to just simply put a blank cover on that box, you could always hang a larger picture above it so that it covers up the box on the wall. Just an idea...
Let us know if you need any help with wiring diagrams for your planned circuit.
Old 09-02-2008, 09:56 AM   #8
Winchester's Avatar
Rewards Points: 150
Covering the box with a blank cover would be the easy way but if you knew me, I never seem to take the easy route. But then again, I hate doing drywall. LOL
Would it be possible to cut it out with a jigsaw? Going around the perimeter of the box? Techinically just the mounted side and probably a knife around the others?
Old 09-02-2008, 11:07 AM   #9
Rewards Points: 506
What I meant by being difficult to remove the existing box is, running new wire from the light to the new switch box location. Without doing a lot of drywall work, there really isn't an easy way to do it. Yes you could cut out the existing box with a jigsaw, but you'd need to be able to run the new wire up to the light box, and I think you will find that part difficult to accomplish.
Old 09-02-2008, 06:33 PM   #10
Winchester's Avatar
Rewards Points: 150
I was thinking how it would be rather simple attaching the new wire to the old and pulling it down but now that I think about it. The wire is probably stapled in the wall? GRRRRR.
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
buried junction box shadango Electrical 28 04-09-2010 05:49 PM
Junction box in patio ceiling I_think_I_conduit Electrical 6 08-20-2008 08:28 AM
Junction Question? fw2007 Electrical 10 03-31-2008 12:03 PM
