3-Way Dimmer Circuit w/ questions
I currently have a regular light switch for our dining room table that I feel was placed in a poor position.
Similarly in an adjacent room, the light switch for our four seasons room was poorly placed around the corner. In other words, it's not in the room for which it's being used. Where it should be located, is a switch for an outdoor light. I cannot place a 2 gang box here because of the wall construction (lack of room) but will place a double switch most commonly found in bathrooms with vent & light combinations. Back to the dining room light. I've just recently installed a new chandelier and it desperately needs a dimmer. I already had in my possession a set of 3-way switches that include dimmers that I would like to install. The original location of the four seasons room light switch will now house one of the 3-way switches. While on the opposite side of the room I'd like to install the other 3-way. This long explanation takes me to my question. Can the single gang box from which I'd like to remove the original chandelier switch be covered, made to be a junction box, and drywalled over like it was never there? This is my first question asked on this forum. Much thanks in advance. |
Correct Circuit?
1 Attachment(s)
#1 is my source
#2 is the current switch for which I wish to remove. #3 would be my master 3-way switch #4 is the switch for the 4-season room light for which will be moved and the slave 3-way switch inserted. Red path is the existing circuit for which I wish to remove. Blue path to the master 3-way Yellow path to the slave 3-way Green path to the chandelier Would this be the proper method for installing this circuit? Correct me if I'm wrong, but the yellow line would be my only 3-wire? Any help appreciated. |
The yellow path would be your only 3 wire circuit. |
I have an unfinished basement below. Above is the second story. |
Hmm, that will make it difficult to remove that existing box. My suggestion would be to just simply put a blank cover on that box, you could always hang a larger picture above it so that it covers up the box on the wall. Just an idea...
Let us know if you need any help with wiring diagrams for your planned circuit. |
Would it be possible to cut it out with a jigsaw? Going around the perimeter of the box? Techinically just the mounted side and probably a knife around the others? |
What I meant by being difficult to remove the existing box is, running new wire from the light to the new switch box location. Without doing a lot of drywall work, there really isn't an easy way to do it. Yes you could cut out the existing box with a jigsaw, but you'd need to be able to run the new wire up to the light box, and I think you will find that part difficult to accomplish.
| All times are GMT -4. The time now is 12:02 PM. |
