Single Gang With 5 Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 10:52 PM   #1
Rewards Points: 150
single gang with 5 wires
I will have wire for the following.
-power feed
-vanity light
-shower light
-exhaust fan
-power to outlet
but the problem is i have a single gang with only 4 inserts. should i just double up to a double gange even tho i wont be using the right side?
fabian is offline   Reply With Quote
Old 01-24-2009, 10:59 PM   #2
Rewards Points: 12
Can I ask why you are trying to squeeze all of that into one single gang box? Traditionally you would have power to the outlet, and then switch the vanity light and exhaust fan and shower light.
mccabegc is offline   Reply With Quote
Old 01-24-2009, 11:00 PM   #3
Why not string the power from Switch -> Vanity -> Shower -> Fan (or whatever order would work best)? Add the outlet to whichever light/fan is closest. If you want to run everything from the one box, get a two gang with a one gang mud ring.
Mthrboard is offline   Reply With Quote
Old 01-25-2009, 05:40 AM   #4
How would he do that?
jerryh3 is offline   Reply With Quote
Old 01-25-2009, 05:43 AM   #5
-power feed
-vanity light
-shower light
-exhaust fan
-power to outlet
Can you just use a three gang with three separate switches? I"m assuming you want to control all of these independently?
Old 01-25-2009, 06:24 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
THIS is the correct answer.
Why in the world would you use a single gang box for this???
Old 01-25-2009, 08:57 AM   #7
Electrician
Rewards Points: 794
I am with Petey on this one, spend the extra money and put in a 3 gang box.
If for some reason you want all this on 1 switch you can buy a 4x4 box(deep or shallow someone can tell you, the Canadian rules may be different then the US) then buy a 1/2" plaster ring for the box and you will have lots of room for your wires.
darren is offline   Reply With Quote
Old 01-25-2009, 01:19 PM   #8
Cow
How do you know that is the correct answer when you don't know exactly what the OP is trying to accomplish?
Maybe he wants to turn it all on at once, why would you want a 3 gang box for that? Like Mthrboard said, maybe he just needs to daisy chain his lights and fan together rather than bringing seperate feeds for each out of one box.
Bottom line, I think he needs to explain himself a little more so we can understand what he's trying to achieve before you assume you know what the correct answer is for him.
Cow is offline   Reply With Quote
Old 01-25-2009, 01:54 PM   #9
please give a diagram of what you have and what you want in the bathroom. Where the existing power feed is and so on
If its a gutted room, I guarantee there will be an easier way
II Weeks is offline   Reply With Quote
Old 01-25-2009, 04:34 PM   #10
Because:
A) I am omniscient.
B) There is NO WAY he'd want to turn all that on at the same time.
Old 01-25-2009, 04:38 PM   #11
joed's Avatar
Rewards Points: 12,858
10 #14 + all the ground wires alone is 21 ci. No 2x3 device box can hold that many. Never mind adding a switch or receptacle.
Old 01-25-2009, 05:18 PM   #12
If you want to do something really smart, put your ex fan on a seperate 2/5/10/15 minute timer switch. You don't want it on every time you turn on the light and often you want to leave it on for a few minutes.
220/221 is offline   Reply With Quote
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Help with single pole switch ballutster Electrical 2 10-13-2008 07:57 PM
Single Gang Box used as a Junction? Winchester Electrical 9 09-02-2008 05:33 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
