-   -   single gang with 5 wires (http://www.diychatroom.com/f18/single-gang-5-wires-36762/)
fabian 01-24-2009 11:52 PM
I will have wire for the following.
-power feed
-vanity light
-shower light
-exhaust fan
-power to outlet
but the problem is i have a single gang with only 4 inserts. should i just double up to a double gange even tho i wont be using the right side?
mccabegc 01-24-2009 11:59 PM
Can I ask why you are trying to squeeze all of that into one single gang box? Traditionally you would have power to the outlet, and then switch the vanity light and exhaust fan and shower light.
Mthrboard 01-25-2009 12:00 AM
Why not string the power from Switch -> Vanity -> Shower -> Fan (or whatever order would work best)? Add the outlet to whichever light/fan is closest. If you want to run everything from the one box, get a two gang with a one gang mud ring.
jerryh3 01-25-2009 06:40 AM
How would he do that?
jerryh3 01-25-2009 06:43 AM
-power feed
-vanity light
-shower light
-exhaust fan
-power to outlet
Can you just use a three gang with three separate switches? I"m assuming you want to control all of these independently?
Speedy Petey 01-25-2009 07:24 AM
THIS is the correct answer. :thumbsup:
Why in the world would you use a single gang box for this???
darren 01-25-2009 09:57 AM
I am with Petey on this one, spend the extra money and put in a 3 gang box.
If for some reason you want all this on 1 switch you can buy a 4x4 box(deep or shallow someone can tell you, the Canadian rules may be different then the US) then buy a 1/2" plaster ring for the box and you will have lots of room for your wires.
Cow 01-25-2009 02:19 PM
How do you know that is the correct answer when you don't know exactly what the OP is trying to accomplish?
Maybe he wants to turn it all on at once, why would you want a 3 gang box for that? Like Mthrboard said, maybe he just needs to daisy chain his lights and fan together rather than bringing seperate feeds for each out of one box.
Bottom line, I think he needs to explain himself a little more so we can understand what he's trying to achieve before you assume you know what the correct answer is for him.
II Weeks 01-25-2009 02:54 PM
please give a diagram of what you have and what you want in the bathroom. Where the existing power feed is and so on
If its a gutted room, I guarantee there will be an easier way
Speedy Petey 01-25-2009 05:34 PM
Because:
A) I am omniscient. :thumbup:
B) There is NO WAY he'd want to turn all that on at the same time. :whistling2:
:laughing: :laughing:
joed 01-25-2009 05:38 PM
10 #14 + all the ground wires alone is 21 ci. No 2x3 device box can hold that many. Never mind adding a switch or receptacle.
220/221 01-25-2009 06:18 PM
If you want to do something really smart, put your ex fan on a seperate 2/5/10/15 minute timer switch.:yes: You don't want it on every time you turn on the light and often you want to leave it on for a few minutes.
