-   -   single to double gang remodel (http://www.diychatroom.com/f18/single-double-gang-remodel-60834/)
DIYGST 01-02-2010 03:23 PM
Can you swap out a single gang remodel switch box to a double remodel one easily? I assume you just unclip the box and cut it wider?
Scuba_Dave 01-02-2010 04:28 PM
Yes, as long as there isn't an obstruction in the wall
Usually it's fairly easy
Take out the old box, verify room to cut a bigger hole
Cut the hole & install new box
frenchelectrican 01-02-2010 05:08 PM
Yes and No depending on which type of box and the way the cables run into the box most percentage it useally not a major issue however most box useally have two nails expect the steel box that kinda toss up depending on the type of junction box.
To remove the single gang box to two gang box .,
Before you start that make a note of wireing connections first this is very important part otherwise it will be a headache to get it hook up right again after you change the junction box.
Once you mark them down what they are for and how it hook up.
then take a old screwdriver or prybar and pry it to one side most case it will pop off then twist the box it will come out.
To install the new box normally I get what we call Smart Junciton box { not all big box store may stock this } otherwise a old work junction box will work in this useage.
This is a link so it may give you some idea how we use for old work boxes
But not all big box store will stock this item otherwise electrical supply centre will have this.
http://www.arlcatalog.com/Miscellane...et%20Boxes.htm
Merci,Marc
Jim Port 01-02-2010 06:33 PM
After making sure I have room for the larger box I cut the hole and then remove the old box. This allows better access to the nails holding the box in place and more room to work in.
Like French, I like the old work boxes that can be screwed into the stud for a nice secure mount.
