Single Conductors Straight To Service Panel From Outside - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 05:18 PM   #1
Question
Single conductors straight to service panel from outside
Hi,
I am hooking up a portable generator behind my shed (about 50 ft from the house). So far, I've buried the four single conductor #10 THHN/THWN wires in a 1" conduit from the house to shed. Seemed easy enough, except for all the rocks in my way ;-).
My question is about coming back into the house. I was told by a couple Home Depot guys that I have to terminate it in a box and run Romex to the panel. The panel is directly below the entry point. I came in directly adjacent to the main service entry to the house, which is a big 2"+ conduit straight into the service panel. Being lazy, I would like to just run the single conductors straight down to the panel (about 30" ), or do I need to put it a box? If so, what type of box. None I find have 1" entry for conduit AND Romex type outputs. Any guidance would be appreciated.
Thanks,
Dave
diydaves is offline   Reply With Quote
Old 11-15-2011, 05:35 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
You either need to run conduit to the panel, or change over to romex inside a box.
Old 11-15-2011, 06:01 PM   #3
Rewards Points: 734
PVC conduit?
You could find a reducer fitting, 1" to 3/4". Any big box store will have a junction box with 3/4" and 1/2" knockouts.
AandPDan is offline   Reply With Quote
Old 11-15-2011, 09:51 PM   #4
Hi jbfan,
So can I use any surface mount box and just drill out the back to bring in the conduit stub? I didn't see much in the way of suitable boxes other than steel. Looks hard to put a 1" hole in it and the blue plastic variety don't seem to come in surface mount. I saw a PVC outdoor box 4x4x2 with flanges but no holes. Would this work? Just drill my own holes?
Thanks,
Dave
Old 11-15-2011, 11:14 PM   #5
Mad Scientist
Yeah, with those grey PVC boxes you just drill your own holes where you need 'em. If it were me, I'd try to just complete the conduit run all the way into the panel, if feasible.
McSteve is offline   Reply With Quote
Tags
generator , hookup , house
Fireblocking around electrical service panel dbmjmj Building & Construction 0 07-11-2010 06:51 PM
service panel wires douglascase Electrical 3 06-12-2010 04:28 PM
Can I wire a new panel without service or run a "big" subpanel? tigereye Electrical 7 03-03-2009 05:00 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 06:41 AM
