Single Circuit Switched Neutral Transfer Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2013, 11:55 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by patmurphey
If you're so concerned, use the "contact us" on the web-site and ask. Earlier versions did not have the stamp. Anyway, I thought I saw it. I don't work for them. UL on the cover of any electrical device is not an indication that it is listed?
It would indicate that the cover is listed. Otherwise there would be a UL listing in its literature.
It would be the same thing as constructing an extension cord with all UL listed materials, but that cord not being UL listed as an assembly, so the safety inspector cuts the cord end off.
Old 12-31-2013, 11:57 AM   #17
k_buz's Avatar
I'm not that concerned...no more than any other thread, I'm just correcting some possible mis-information.
Old 12-31-2013, 12:24 PM   #18
Rewards Points: 149
You piqued my curiosity. Here is a link from a year ago. Make sure to click the "see more". Don't know what has happened since.
https://www.facebook.com/EZGenSwitch...51105261376401
patmurphey is offline   Reply With Quote
Old 12-31-2013, 12:44 PM   #19
k_buz's Avatar
So...at that time, it wasn't listed but used listed parts. I'm not saying its unsafe, but it is not legal to install without special permission.
Old 12-31-2013, 01:21 PM   #20
Rewards Points: 149
A question. If you were called by a customer to install a solution to this scenario, how could it be done legally and/or safely?
Hot water furnace hard wired. Neighbor has standby generator power with neutral bonded at the service entrance switch. Winter outage and neighbor offers an extension cord from his home to power furnace. It appears that the only 2 companies that offer single circuit 120 volt/15 amp transfer switches that switch the neutral have only the components listed.
I'm the neighbor with a standby generator and I learned the hassle that portable generators are during a long area wide outage, during Sandy and Irene. I'd like to pay forward the assistance a former neighbor gave me.
If I were in Wisconsin, I'd be happy to offer the business.
Old 12-31-2013, 01:43 PM   #21
k_buz's Avatar
I wouldn't install it. I could come up with a better way.
What you are missing is that I can make that EXACT same part and it would be legal, but if it's sold as an assembly, the assembly has to be listed.
Old 12-31-2013, 02:29 PM   #22
Rewards Points: 149
Better way doesn't appear to be available. Or, just take it apart and assemble it on site.
thanks for your time.
Neutral on a dead circuit teamo Electrical 10 12-11-2012 01:10 PM
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 03:39 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Circuit tester shows open neutral; multi-meter says something different. fredgmeyer Electrical 11 10-26-2009 12:41 PM
