Single Circuit Switched Neutral Transfer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 05:09 PM   #1
Rewards Points: 29
I know this isn't a product recommendation forum, but maybe we can look at this as a "does this product exist" question?
I am hooking up a transfer panel for a Generac XP8000E. I am using the 30A 240 v outlet, an outdoor power inlet box, and a 30A switched neutral transfer panel.
The generator is rated 33.3A/41A Max. I was thinking that, in order to maximize the power I can get during any motor startup situations, that I can use one of the 120V 15A plugs, and wire in a separate switch for the furnace blower.
My problem is that I can't find a single circuit transfer switch that switches the neutral. Does this exist, or will I need to make my own?
kaalapurushha is offline   Reply With Quote
Old 12-29-2013, 06:37 PM   #2
joed's Avatar
Rewards Points: 13,286
If the furnace circuit is already transferred to the generator then you all you need is an on off switch for the furnace to control when it starts.
Old 12-29-2013, 07:44 PM   #3
Rewards Points: 760
The 15 amp receptacle on your generator is connected internally to one of the two windings your 30 amp receptacle uses.
There is nothing to be gained. You won't have any more capacity.
AandPDan is offline   Reply With Quote
The Following 2 Users Say Thank You to AandPDan For This Useful Post:
brric (12-29-2013), stickboy1375 (12-30-2013)
Old 12-30-2013, 08:06 AM   #4
Rewards Points: 29
Then how can the generator have a max ampacity greater than any one of its outlets? Are there any outlets which are truly independent?
I thought that for a 30A 240V transfer panel, you can get 30*240 = 7200 Watts. The generator is rated 8KW and can surge to 10KW for 30 minute intervals. There has to be more capacity in one of the outlets.
Old 12-30-2013, 08:43 AM   #5
Rewards Points: 760
Sure, you can pull 4000 watts off of each leg but it still uses the same windings. You still need to balance the loads on both 120 volt legs.
The outlets are for convenience, that's all. Look at the 8kw label as a marketing tool. It should have had a 50 amp 120/240 volt receptacle if it was designed to function at 8kw continuously.
Old 12-30-2013, 09:33 AM   #6
Rewards Points: 149
EZ Generator switch. There are videos in the link, showing installation.
EZ Generator Switch | Manual Transfer Switch
patmurphey is online now   Reply With Quote
Old 12-30-2013, 09:50 AM   #7
Rewards Points: 29
Seems sketchy. Does it have a center off? I would think that a center off is required for it to be to code.
Old 12-30-2013, 10:48 AM   #8
Rewards Points: 149
It's UL listed and switches both the hot and neutral in a 120volt 15amp circuit. No center off is necessary - you are either on utility or generator, never both. I doubt that it could be listed if both are connected during the throw.
As others have said, I wonder why you really need this separate connection.
Old 12-30-2013, 01:39 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It's called marketing scam....
The Following User Says Thank You to stickboy1375 For This Useful Post:
AandPDan (12-30-2013)
Old 12-31-2013, 05:31 AM   #10
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
here is the best set up most flexibility for manual transfers .. its a kit ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 12-31-2013, 06:11 AM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It's UL listed
Where does it say that?
Old 12-31-2013, 06:31 AM   #12
Rewards Points: 516
correct @ 240 volts 7200 watts ///
OR
120 x 30 = 3600 watts x 2 = 7200 watts ///
Old 12-31-2013, 08:29 AM   #13
Rewards Points: 149
UL is stamped on the front of the box. Look at the lower center of the picture. It is also stated on their web-site.
Old 12-31-2013, 10:49 AM   #14
k_buz's Avatar
That UL stamp is for the cover, not the assembly. I looked on their website looking for a listing and couldn't find it. If you have a specific location for me to look, please point it out.
Just because the parts of the assembly are all UL listed doesn't make the assembly UL listed.
Old 12-31-2013, 11:07 AM   #15
Rewards Points: 149
If you're so concerned, use the "contact us" on the web-site and ask. Earlier versions did not have the stamp. Anyway, I thought I saw it. I don't work for them. UL on the cover of any electrical device is not an indication that it is listed?
Neutral on a dead circuit teamo Electrical 10 12-11-2012 01:10 PM
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 03:39 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Circuit tester shows open neutral; multi-meter says something different. fredgmeyer Electrical 11 10-26-2009 12:41 PM
