Single Circuit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 04:37 PM   #16
I=E/R
a7ecorsair's Avatar
You should take a hard look at what power you may need in the future. How far is it from the house to the shed? Since you will be trenching, do it right the first time
A MWBC will give you some basic power. A sub panel will require a little more work since you will need a ground rod, larger wire to feed it, and a panel board.
Any plans for a welder? I thought all tractor sheds had a welder
a7ecorsair is offline   Reply With Quote
Old 02-08-2011, 05:39 PM   #17
mem
Rewards Points: 156
And if you don't have a welder, having 240 in the shed is a good reason to get one!
mem is offline   Reply With Quote
Old 02-08-2011, 06:28 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,036
One thing about this site is you will get lots of opinions.
The reason in your first post I suggested GFCI at the house is it reduces the burial depth fro 24 to 12 inches. If you try to get 240 and 120 volts or you exceed 20 amps,you will have to have a sub panel in the shed.
Yes a disconnect is requires at the shed but for 20 amp circuits this can be a regular switch.
Coastal South Carolina
Old 02-09-2011, 10:17 AM   #19
Thanks guys. Good info, 12' burial with GFCI...worth the extra $ for sure!
Joe Willie is offline   Reply With Quote
Old 02-09-2011, 10:24 AM   #20
Down in Katrina Land, we all have generators to run our well pumps, so I've got big juice if I need it. This setup I'm planning is primarily to keep my chicken and speckled trout frozen, the beer cold, and some light for a card game. Thanks again for the input.
Old 02-09-2011, 12:04 PM   #21
Rewards Points: 64
Originally Posted by a7ecorsair View Post
J.V.
Could the OP run 10/3 as a MWBC. This would give him more options.
Yes, he could and would have more capability. He would need to start looking at cost. 10/3 UF cable is not cheap. Personally I would opt for the sub. But the OP is interested in a single circuit. Unless you guys have changed his mind?
Originally Posted by Joe Willie View Post
I thought 10-3 would make this a multi-circuit and require a panel?
No panel required for a MWBC. Never has been required. If you mean you cannot run more than one circuit or feeder to the unattached structure you are correct. A MWBC would be the exception to this rule.
J. V. is online now   Reply With Quote
Rewiring older house WillK Electrical 12 10-13-2010 02:49 PM
Different AWG in single circuit iceclimber2001 Electrical 11 04-16-2010 12:24 AM
Maximum Outlets/Daisy Chains on a Circuit HooKooDooKu Electrical 9 04-13-2010 08:08 AM
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 07:17 AM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
