Single To 3 Phase Invertors/converters - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2007, 04:11 PM   #1
Single to 3 phase invertors/converters
Hi Guys/gells I'm mr Newbee!!!!
I'm after a bit of help in getting a 3 phase industrial circular saw, to run from my single phase 240v supply......
I've got a 415v invertor?/convertor? (very old) from a local garage that used it to power the car lift and wired it in, and i tried the motor in both STAR and DELTA but it will not run. I know a little about electrics and motors but nothing to shout about so i thought i'd ask you guys.... but go easy on me, so i can take it all in
Any help much appreciated..
bantanic is offline   Reply With Quote
Old 02-05-2007, 05:20 PM   #2
Rewards Points: 150
You could troubleshoot it further by CAREFULLY measuring each line to ground, and to eachother to make sure you have the power correct... post the results
elementx440 is offline   Reply With Quote
Old 02-05-2007, 05:28 PM   #3
joed's Avatar
Rewards Points: 12,878
Post specs on the saw and the inverter.
Old 02-06-2007, 07:53 AM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Also may want to try the power tools forum on woodnet.
http://www.forums.woodnet.net/ubbthr...at=&Board=UBB2
Brik is offline   Reply With Quote
Old 02-07-2007, 03:49 AM   #5
Hi TroubleX....
I've checked each line to ground and i'm sure that.
BLACK is 393v ish
BLUE is 234v ish
RED is 193v ish
Is this the problem shouldn't each phase be 240v or 415 phase to phase to run, i'll try and get more info on the inverter...
Thanks guys.
Old 02-07-2007, 10:19 PM   #6
Rewards Points: 150
the voltages look a little suspect. What's the requirement of the saw motor?
"STAR and DELTA" is known at "WYE and DELTA" also. Delta means triangle shaped, WYE is, well, like a "Y" shape. Anyways. STAR/WYE expects three lines and a neutral (4 wires total).
DELTA configuration assumes a balanced load, therefore, no neutral required... just the three lines.
What's your measurements line to line?
In WYE, the voltage between any two lines is 1.7 times the voltage from a line to neutral. In DELTA, the voltage should be the same between all the lines...
Post some model numbers too...
Old 02-09-2007, 09:20 AM   #7
Hi Guys
I've had a look at the inverter/converter (which is it any how?)
but i can't find a make anywhere on it.
The saw is a dewalt circular saw with 18" blade 3HP motor it came from an industrial work place with 3 phase supply and could be plugged straight into the wall via a round 4 pin plug.
I've taken a picture of the inners of the inverter to show the links.
Does anyone know what the letters R.S.T stand for on the armoured cable link, i've connected the L N E to the mains and the armoured cable to the stop start box on the saw where the original plug was, the others must be to control the voltage are they?. ( is this correct)......
If i'm trying to run the saw from a single phase supply, the inverter capasators splits the 240v supply into 3 for the U,V,W phases,
So across each phase i should get a reading of 415v....
As it's wired now when you hit the start button the saw blade attempts to run but the start button wont hold in and just breaks contact......all in a thousanth of a second.
heating element 240 volt single phase geeyathink Electrical 19 02-20-2011 06:57 AM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-23-2009 11:06 PM
3 phase anyone? Tomkah Electrical 3 01-05-2007 05:18 PM
3 phase electricity J187 Electrical 11 10-26-2006 01:40 PM
