Singed Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 12:21 PM   #1
Singed Neutral
I noticed inside my panel that one of the 12ga neutrals was a little burnt near its screw at neutral bus. I tried to remove it but couldn't turn the screw--it was locked up. Finally I cut it and re-terminated it under another screw.
--Could this this have been caused by the screw being loose?? (I can't tell since it was locked?)
--What else may have caused this? How much of a concern is it? (I've never blown any fuses)
Thanks in advance.
capt2 is offline   Reply With Quote
Old 09-01-2008, 02:26 PM   #2
Possibly. It could have also been cause by an overloaded circuit.
Are there any red wires attached to any breakers?
It is not uncommon to have multi circuit branch circuits in houses. A 3 wire cable is run from the panel to a junction somewhere inside where it splits off into 2 circuits. In this installation the two circuits "share" the neutral.
This works fine if the two circuits are on opposite "phases" but if they are on the same "phase" the neutral will be carrying twice the load it was intended for.
If you have red wires in your panel, make sure that the black, in the same cable is on the opposite "phase" or leg.
The phases alternate top to bottom A, B, A, B etc.
Burned neutrals...not a very clear pic but several are burned/discolored.
220/221 is offline   Reply With Quote
Old 09-01-2008, 02:35 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
In addition to what 220/221 said:
12 ga is good for 20 amps. Is the panel fused or have breakers?? 'Over-fusing' a circuit can melt/burn wires, but yours sounds like it could have been loose, and now the screw is probably welded from the heat.
FYI...neutral wire terminations can only have one wire under a screw.
Old 09-01-2008, 04:17 PM   #4
Registered User
Termite's Avatar
I'm with 220/221...
This just smells like an overloaded neutral from an improperly phased multiwire branch circuit. If the lug were loose I'd find the burnt area easier to attribute to a bad connection...But it wasn't loose.
Capt2, if you aren't 100% confident in your electrical abilities, please call an electrician. If the neutral is cooking in the panel, it could be cooking somewhere else in your house just as easily. This is the sort of thing that will burn a house down before a breaker trips.
Old 09-01-2008, 04:18 PM   #5
electrical contractor
Rewards Points: 150
sd515 that is not always the case. I install alot of Cutler Hammer load centers, and the instructions inside the door state the neutral bus terminals are good for up to 3 awg 12 wires, but they must be the same size and material.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 09-01-2008, 04:24 PM   #6
Isn't that only when they are grounds? Doesn't the NEC allow only one grounded(neutral) wire in each screw terminal?
jerryh3 is offline   Reply With Quote
Old 09-01-2008, 05:14 PM   #7
Originally Posted by jerryh3 View Post
... Doesn't the NEC allow only one grounded(neutral) wire in each screw terminal?
That's correct. Article 408.41 prohibits terminating another wire in the same terminal as a grounded (neutral) conductor. There is an exception for parallel grounded conductors if the terminal is identified for more than one wire.
Matsukaze is offline   Reply With Quote
Old 09-01-2008, 05:45 PM   #8
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
In my experience when a wire is subjected to overload, the insulation is discolored over it's length. When the discoloration is only a small section next to the terminal, it has been caused by a loose connection. A terminal screw bound up from the heat confirms the loose connection theory for me.
Take another look at it in a few weeks or months.
John
jrclen is offline   Reply With Quote
Old 09-01-2008, 06:52 PM   #9
Rewards Points: 508
Send a message via AIM to theatretch85
I would agree with jrclen. I created a thread on here a few weeks ago regarding a melted service entrance wire in a main panel, where the last 4 inches or so were melted and charred, and attempting to tighten the lug down on the loose wire it was stuck in place (seized from the heat buildup).
Loose connections are no good, when the wire doesn't make a solid connection it builds up heat as the electricity is trying to make the connection, the more current you try pulling through that loose connection the worse it gets. Just be glad that loose neutral was on a branch circuit and not the main breaker! in the instance I saw the charred wire entering the main breaker, the whole panel needed to be replace and cost about 4,000 to do so.
theatretch85 is offline   Reply With Quote
Old 09-01-2008, 07:06 PM   #10
Thanks for the replies. There is no red wire or multi-wire circuit involved. And it IS just burned near the bus only. A loose screw sounds like the best news if that is the case. And yes I will re-check the wire near the new screw that I re-terminated it to--in a few weeks. THANKS again.
Old 09-01-2008, 07:57 PM   #11
Electrician
SD515's Avatar
Rewards Points: 504
Twister...next time you get a chance, would you double check that label. I would be curious to know if those LC's actually state 'neutral/grounded' wire or 'grounding' wire can be up to 3. As Matsukaze stated, I know 408.41 prohibits 'grounded', but they do not prohibit 'grounding' (bonding).
Originally Posted by SD515 View Post
...sounds like it could have been loose, and now the screw is probably welded from the heat.
Originally Posted by jrclen View Post
...A terminal screw bound up from the heat confirms the loose connection theory for me.
Same principle an arc welder works on. A loose connection creates a gap for an arc...the arcing welds the screw.
Old 09-01-2008, 09:00 PM   #12
Rewards Points: 150
The label states the same for both the grounded, and grounding bus bars.
Jimmy
Old 09-02-2008, 08:43 AM   #13
jrclen's Avatar
Rewards Points: 514
NEC 408.41 Each grounded conductor shall terminate within the panelboard in an individual terminal that is not also used for another conductor.
Exception: Grounded conductors of circuits with parrallel conductors shall be permitted to terminate in a single terminal if the terminal is identified for connection of more than one conductor.
The NEC overrides the label on the panel for grounded (white wire) conductors on the bus. Grounding conductors are allowed to comply with the label.
408.41 was put in the code in the 2002 cycle. Prior to that the panel label or listing usually stated one grounded conductor per terminal.
John
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Problem with Neutral Connection kbrigham Electrical 4 03-11-2008 07:00 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
