Singal Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 11:18 AM   #1
Singal Pole switch
I change all the outlets in a room and the switch when I tried to turn on or off the outlet which the switch wwould shut off the outlet stays on switch does nothing. I wired everything the way the old ones were wired as well as the switch. I put the old switch back and still the same issues. Please help
kiriza is offline   Reply With Quote
Old 11-01-2010, 11:32 AM   #2
Rewards Points: 324
on the hot side of outlet that the sw controls,break or cut tab that is between the two hot screws.
oleguy74 is offline   Reply With Quote
Old 11-01-2010, 03:29 PM   #3
Since I haven't broke the tab as of yet can I go to another outlet within the room for the switch to operate as well?
Old 11-01-2010, 03:32 PM   #4
Rewards Points: 324
if you still want a half hot,you break the tab.and it all depends where the switch loop goes(what recp).as long as you have access,you can put it any where.
The Following User Says Thank You to oleguy74 For This Useful Post:
kiriza (11-01-2010)
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 12:48 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
Can anyone I.D this 3 pole switch?? remlu Electrical 12 12-03-2008 02:01 AM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 08:06 PM
