Simplify Sunsmart Setup? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 10:25 AM   #1
Hi! New member here (New Jersey USA). I too, am having all kinds of trouble getting the Sunsmart timer to work. Whoever designed the user interface misses the whole point of a light timer, which is to go on at dusk, and go off whenever you want.
I've gone through the setup several times, the electrician who installed it did too. The outside lights go on, but do not go off as per the set up.
Here's my question; can all those ridiculous settings, like zone, year (I mean, who the heck cares what year it is when turning on night lights, right?), and other needless parts of the setup be by-passed entirely, allowing the user to cut to the chase?
In my setup, I need; a clock to count the hours, a turn-on time, and a turn-off time.
Does anybody know a simple way to do this?
Thanks,
Ducati
Ducati is offline   Reply With Quote
Old 12-17-2011, 10:30 AM   #2
I=E/R
a7ecorsair's Avatar
You should post the model number so we could see if there is an online users guide.
a7ecorsair is offline   Reply With Quote
Old 12-17-2011, 11:25 AM   #3
Model # is on website. On jascoproducts.com it is the SunSmart Digital Timer.
http://www.jascoproducts.com/product...idproduct=1120
D.
Old 12-17-2011, 01:15 PM   #4
I=E/R
a7ecorsair's Avatar
Well, you bought a little more that just an on/off switch.
You will have to take time and go through the setup. It is a 7 day programmable timer and is probably quite similar to modern furnace thermostats.
Old 12-17-2011, 08:05 PM   #5
Thanks for the "help". Now if I could find some one who knows how to program the beast.
D/
Old 12-17-2011, 09:10 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,852
D/
What do you want us to do, come over to your house and program it for you? You bought the thing. If you didn't want a timer with these capabilities, you should have picked something that just does what you want. You bought an "astronomical time clock", as they are called. It has to know the date and latitude so it knows the exact times of sunrise and sunset (yes, there is a lot going on in there). The programming instructions are only one page long, and fairly straightforward as astronomical time clocks go. Just follow the instructions.
mpoulton is online now   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
old furnace with bizarre filter setup utek HVAC 2 10-14-2013 09:49 PM
Honeywell TH8320 Setup Parameters PTHVACMAN HVAC 1 11-14-2011 05:13 AM
New House Structured Wiring Setup for CATV gregsenne Electrical 13 02-19-2009 09:00 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 01:08 PM
