Simple Timer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 09:11 AM   #1
Simple Timer Switch
All too frequently I will go out to my shed during daylight hours and either turn on the lights to get better lighting on my work, or turn on the oscillating fan for ventilation. When I am done, I will lock it up and go into the house.
Some time later, after dark, I will notice the lights are still on and have to trudge back out there to turn them off. Or I might remember to turn the lights off but miss the fan and not discover it is still running until I re-enter the shed about 2 weeks later.
I know the most cost effective answer would be to train myself to turn everything off when I leave the shed, but I am an old dog, and after many years, I still have not learned that trick so I have given up on that approach.
I am looking for a switch that I can flip to turn the lights or the fan on, or both, that will have a timer, such that it turns off after, say, 2 hours. If I am still working, and it turns off, I can always turn it back on, but I can also be sure that within 2 hours of closing up the shed, everything will go off.
Many switches I have looked at are programmable, but they all seem to be oriented to auto on as well as auto off. I do not want the auto on. Some have timer buttons of the type that would be useful, but they also have a manual on/off override. I don't want a such an override because if I get sloppy and hit that, I am back to square one.
I envision a simple switch. Flip it and you have 2 hours (or 1 hour or whatever) of power, then you have to flip it again to get more power.
Now for one complicating factor. I have the light and the fan switches in the same single box. You know, the two switches, one over the other, that operate horizontally rather than vertically. If possible, I would like a double timer switch of the same style. It would be a hardship, though not impossible, to add another box, but I would like to avoid that if I can.
Silkcityflorida is offline   Reply With Quote
Old 12-02-2011, 12:12 PM   #2
I did happen to see this last time at Home Depot when I was looking at some of my own timing needs:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
In regards to not adding another box, if you have a 2 gang box, should be able to use 2 of these.
roidrage152 is offline   Reply With Quote
The Following User Says Thank You to roidrage152 For This Useful Post:
Silkcityflorida (12-02-2011)
Old 12-02-2011, 12:17 PM   #3
Rewards Points: 1,522
These kinds of timers are pretty simple (seem a bit pricey but could shop around):
http://www.zorotools.com/g/Mechanica...ches/00066123/
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Tags
switch problem , timer
Installing timer switch peequi Electrical 11 11-25-2011 04:45 PM
Timer switch at end of run tmaher Electrical 3 05-16-2011 07:06 AM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 12:02 PM
Wiring a digitial timer switch bgajms Electrical 2 12-07-2010 12:40 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
