Simple Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 07:09 PM   #1
Rewards Points: 236
simple questions
hello, guys.
i am putting new 14-3 from a new wall box up to a new ceiling fan/light.
2 dimmer switches = 1 fan, 1 light.
wiring them. i think i just connect the black to 1 switch, the red to the other switch. and the white is split to both. is this correct ?
also. cerrowire . when connecting 2 grounds in a box, with or without an outlet. the outlet screw seems to be only large enough for 1 wire. is it ok to just twist the grounds together ? if not, how do i connect them ?
thanx
Fix'n it is offline   Reply With Quote
Old 07-22-2012, 07:17 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Your 3 wire should be black to one switch, red to the other, white to the neutral of the power feed. The hot of the power feed should be pig tailed to both switches.
You should pig tail the ground as well. Do not put more than one ground under the screw on the device.
Old 07-22-2012, 08:46 PM   #3
Rewards Points: 236
ok, i got it done. thanx
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
Footer size for a monolithic patio that can support simple roof seth Building & Construction 2 05-19-2009 09:19 PM
