-   -   Simple question on transformers from a n00b (http://www.diychatroom.com/f18/simple-question-transformers-n00b-146847/)
turborunner 06-12-2012 05:03 PM
Hello every one, I'm new to the forum and electrisity in general. Here is my first post; Its a simple question hopefully not to simple though. I have a power supply of 20kilo-volts at 0.5 amp. I wanted to know if a transformer could step the voltage down to 120 and raise the amperage to 50amps or ballpark range of? Thanx in advance:thumbsup:
Yoyizit 06-12-2012 05:11 PM
20,000 v x 0.5A = 10 kW. This thing is lethal.
120v x 50A = 6 kW.
6<10, so, yes, at least in principle.
turborunner 06-12-2012 05:20 PM
AWSOME! Thank you so much.
micromind 06-12-2012 08:27 PM
Only if the power supply is AC, or pulsed DC.
If it is just plain ol' DC, it'll burn up the transformer.
P.S. As noted, 20 KV at 0.5 amps is absolutely lethal!! It will kill you instantly if you're not extremely careful. A typical overhead power line in a residential neighborhood will have a minimum or 2.4 KV to ground, usually more like 7.2 KV. And we all know what happens if you get hit with one of those......
This isn't the 20 KV you find in an ignition coil or even an electric fence. Those items produce low enough current that the resistance in your body will cause the voltage to drop to a non-lethal level.
Be careful around this power supply.
Rob
mpoulton 06-13-2012 12:49 AM
Sounds like a homework problem, rather than reality. A 20kV 500mA supply is a heck of a power source. Nobody has that sitting around unless they really know what they're doing.
