Simple Question Regarding Wall Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 11:11 PM   #1
Simple question regarding Wall Switch wiring
Question: I would like to remove the right wall switch of a dual switch arrangement. What wiring changes do I need to make (see current wiring diagram attached)?
Background: I just finished replacing a celing fan with one that has a remote control. Our house is new enough that it has a dual wall switch that activated the previous fan (left switch) and light (right switch).
With the new fan, only the black, white and ground wires are connected from the ceiling box to the fan, and the fan receiver then distributes power to the fan, an uplight and a downlight separately. I have left the wall switches unchanged for now. With this arrangement, the left wall switch will turn on / off the fan and lights to whatever option speed and light combination has been selected last with the remote. The right wall switch does nothing since the red wire from the ceiling box is not connected / used.
The remote has the ability to mount on the wall in place of a wall switch (will still be battery activated, vs. hard wired). It could substitute for the current left or right wall switch (right would be best because then we would still have the simple "quick off" for everything option with the left switch).
I think the answer is that I could just disconnect all wires to the right switch and tape / wire nut off the ends, then remove the switch and insert the remote in that slot? Please let me know if this would work or if some other approach is better.
If this works, I would then have a simple on / off for everything controlled by the left switch, and the remote would be in the wall allowing convenient adjustments to the speed or lights right as you enter the room. We also wouldn't have to worry about another remote lying around the room.
Thank you in advance for the help!!
Simple question regarding Wall Switch wiring-wall-switch-wiring-question.jpg
kebrein is offline   Reply With Quote
Old 11-23-2011, 11:59 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 154
Turn the breaker off, remove switch and put wire nuts over the ends.
Do not remove the splices in case you ever have to change it back..
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
kebrein (11-26-2011)
Old 11-24-2011, 08:25 AM   #3
Rewards Points: 2,512
Do exactly what jbfan says.
Or you could remove your current 2-gang box, cut in a 3-gang box, replace the current two switches in the new 3-gang box and use the 3rd gang for the fan remote.
But sounds like you should do option #1.
hammerlane is offline   Reply With Quote
Old 11-24-2011, 10:28 AM   #4
Thank you for the quick response!
I'll try today and confirm success on the thread today or tomorrow!
Old 11-24-2011, 11:35 AM   #5
Just relax today and watch football.
Old 11-24-2011, 06:06 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,036
Or cap the wire at the ceiling box and leave the switch in place. It always makes people wonder about the mystery switch
Coastal South Carolina
Old 11-25-2011, 08:54 PM   #7
Thanks for the help. I just removed the switch and put wire nuts over the ends as jbfan suggested. Everything works just as I hoped it would and thought it should.
Tags
ceiling fan wiring , remote , wall switch
light switch wiring question. dannat Electrical 4 05-05-2011 10:11 AM
1-pole switch, multple fluorescents: wiring question nelsonC Electrical 9 05-24-2010 09:20 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 03:44 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
