Simple Question, Difficult Answer??? HELP! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 01:21 AM   #1
Exclamation
Simple question, difficult answer??? HELP!
When I started this project, I thought it would be simple, but apparently, it's more tricky than I thought.
I've run 5 new lines in my ceiling, (two for lights, another for one switch, a ceiling fan, and wall sconces) and I've run a new line from my circuit breaker to support these lines. The problem is this:
How do I connect all of these new lines to the one power source? I don't want to just use wire nuts, because that's going to be a mess. I was looking for some kind of manifold or wiring harness to tie into, but I can't seem to find what I'm looking for. There's got to be something out there for this! Help!
Is there something like a harness or manifold that I could 'plug' the power into, and then have connection spots for the other lines?
Thanks so much!!!
rozzy1978 is offline   Reply With Quote
Old 11-02-2012, 01:28 AM   #2
" Euro " electrician
frenchelectrican's Avatar
One way you can use is the Wago connector ( Ideal is simair as well )
This is pretty common item I used over here in France and it kinda pretty common item over in USA side now.
Otherwise split the number of conductor in half and use the jumper and do the other half with two red wirenuts it easier to fold it back in the switch box.
Merci,
Marc
Old 11-02-2012, 11:46 AM   #3
Rewards Points: 78
Junction boxes and wire nuts are the norm. All splices must be accessible.
easiest question I don't know the answer to petros151 Plumbing 4 07-25-2012 06:49 PM
Simple question on transformers from a n00b turborunner Electrical 4 06-13-2012 12:49 AM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 10:32 AM
Very simple stain question. dntnowood Painting 5 01-30-2010 07:37 AM
simple question djcrewz Electrical 7 10-25-2005 12:01 PM
