Old 06-17-2010, 11:58 PM   #1
simple plastic fixtures?
I got some very simple single bulb fixtures for my garage, and I notice there is no ground, I am guessing this is because they are plastic, and there is nothing to energize?
second does it matter what screw I connect the hot wire to, there is a gold screws and a silver screw. Does it really matter how I connect, or is there a method to the madness?
cbzdel is offline   Reply With Quote
Old 06-18-2010, 12:11 AM   #2
Just call me Andrew
Hot goes to gold, netural to silver.
Andrew
secutanudu is offline   Reply With Quote
Old 06-18-2010, 08:50 AM   #3
Why?
Neutral goes to the lamp socket shell that is more likely to be touched accidentally. Hot goes to the center contact inside the socket.
Usually the screws are "sort of" color coded with silver plating for neutral.
For an all plastic bodied fixture, leave the ground wire coming into the box curled up and unconnected, or connect it to the box itself if the box is metal.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 05:43 AM
Plastic - using plastic to make your own replacement parts Hemingway General Discussion 5 09-26-2009 08:49 AM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 05:08 PM
Corrugated plastic fixtures tonydee Roofing 4 07-16-2008 11:36 PM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 03:42 PM
