I managed to get pictures from my cell phone to the work computer. These are of the timer and wiring that was there before, including the photocontrol that I'll no longer want to use.
Originally Posted by AllanJ
Is the photocontrol still there?
I removed it. It's sitting in my garage at the moment. I bought a new one and rewired it back the same way, just to test things out, but the lights still didn't work. I'm guessing the timer itself was busted, because it looked old old old and had seen better days.
Where in the panel are the two black wires from the panel connected?
I'm not sure, all I see are the breaker switches.
What voltages do you get when measuring across the various wires (all possible combinations of two at a time)? Assuming you get almost zero volts measuring between the two blacks out to the lights, the white out to the light and white to the panel (all possible combinations of two) try applying power to the blacks to the light and the white to the lights (all three combinations of two at a time). What happens?
My electrical knowledge is very limited, I didn't even know I was supposed to measure in combinations of two. I'll check this out tonight, I had just been holding my red and black tester things to each wire one at a time and was getting very small numbers.
