Simple Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2006, 09:22 AM   #1
simple light switch
Need advise on how to wire my switch. I have two switches and one light. How can i wire it so that i can use either switch anytime, with the other switch in either position? Thanks.
sedwick is offline   Reply With Quote
Old 09-25-2006, 11:03 AM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Are you replacing exisiting switches and lights or adding new ones? The short answer is, you use special switches called 3-way switches to control a light from two locations. The switches have no up side, so if the light is on when one is down the other is up and if you flip the one that is down up the light would go OFF and vice versa.
I can tell you how to actually wire this circuit, but I'll need to know where you will be bringing the power through, the light, a switch, etc. Also, is the light between the switches or not?
J187 is offline   Reply With Quote
Old 09-25-2006, 11:23 AM   #3
I've added a room next to the house, it had an existing outside light and switch on the inside. I've installed receptacles around to the new switch, so i have power at both switches. Thanks.
Old 09-25-2006, 01:38 PM   #4
J187's Avatar
Rewards Points: 508
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Adding a light switch.... truebaca Electrical 6 07-18-2007 05:42 PM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 03:27 PM
Light switch not working! jtbel Electrical 4 12-09-2006 07:34 PM
