Simple Grounding Question. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-20-2008, 03:19 PM   #16
electrician
Originally Posted by CowboyAndy View Post
No, dont worry about it. Just make sure it doesn't touch the hot and neutral terminals on the receptacle and you are good. If the box is a metal box, then that ground has to be bonded to the box as well. make another pigtail and connect it to the metal box. There may be a grounding screw existing, or provisions for one (a tapped hole) where you can use a green ground screw.
That's not 100% accurate either. According to NEC 250.146(B)
(B) Contact Devices or Yokes. Contact devices or yokes designed and listed as self-grounding shall be permitted in conjunction with the supporting screws to establish the grounding circuit between the device yoke and flush-type boxes.
This means if you buy the receptacles with the "auto-ground clip", you only need to ground either the box or the rec.
Silk is offline   Reply With Quote
Old 03-20-2008, 05:40 PM   #17
When is fishing season?
CowboyAndy's Avatar
Yes, you are right...
i was going on the assumption that it was a standard recep, not a self grounding.
Im sure if i mentioned self grounding, you would have been right here pointing out that it could be a standard...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 08:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 09:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 04:14 AM
