Simple Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 06:32 PM   #1
Rewards Points: 14
Simple grounding question
This is a stupid question probably but i'd rather ask than assume... On recepticals there is only one screw for the ground wire. Do i need to wire nut the two ground wires together then run a pigtail to the receptical or can i just wire one to the receptical and then twist the other ground around that one
fgunternahrer is offline   Reply With Quote
Old 09-03-2012, 06:35 PM   #2
Rewards Points: 13,250
Pig tail it, only one wire under each screw.
Old 09-03-2012, 06:37 PM   #3
Rewards Points: 14
why do they only put one ground screw on the recept it would be so much simpler if they would put two screws on like they do for the power and common
Old 09-03-2012, 06:40 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Not a stupid question....but a common one here.
Do a search on Pig Tails......Basically, you create a pig tail between the in box wiring and your outlet....hence, you end up with just one wire to the outlet.....makes life easier...
Old 09-03-2012, 09:35 PM   #5
Electrical Contractor
kbsparky's Avatar
You must use a pigtail, AND a listed pressure-type connector, such as a wire-nut or crimp sleeve.
You should NOT simply twist the wires together, without a proper connector.
-KB
Old 09-04-2012, 04:35 PM   #6
Rewards Points: 14
yeah thats kinda what i thought the answer would be i was just hoping other wise
Old 09-04-2012, 04:57 PM   #7
Rewards Points: 77
Lol, yeah, doing it the right way might add .03 cents in cost and 1 minute of extra work
patented is offline   Reply With Quote
Old 09-04-2012, 06:43 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Code violation for one, they actually used to make devices with two ground screws, but if you were to remove a device, you would lose your safety protection down stream of the circuit... so it only makes sense to not allow a device to sustain this protection.
The Following User Says Thank You to stickboy1375 For This Useful Post:
zappa (09-04-2012)
Grounding question Raym50 Electrical 38 08-05-2012 11:30 AM
Grounding question tmbleweed Electrical 11 01-12-2011 11:27 PM
grounding question Skippymartinez Electrical 1 11-30-2009 08:19 AM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 09:25 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 05:14 AM
