Simple Conduit Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 02:28 PM   #1
Insatiable Learner
Rewards Points: 166
Question
I'm going to be running some 10/3 wire for a generator. I also will be upgrading my garage for 20 amps, so I'll be running some 12/2 for that. They are both being run along the same area of the house.
For the 10/3 I am running the wire in some conduit. Is there any reason why I couldn't also run the 12/2 inside the SAME conduit? Or would I need to run it (the 12/2) in a separate conduit? Thanks.
AngelArs is offline   Reply With Quote
Old 03-21-2013, 03:29 PM   #2
joed's Avatar
Rewards Points: 11,610
If the conduit is big enough then you can run them both in the conduit as long as the conduit is only for protection. If you terminate both ends in junction boxes then you must run individual THHN/THWN wires.
Old 03-21-2013, 03:47 PM   #3
Insatiable Learner
Rewards Points: 166
Question
Yes, it's only for protection. Can PVC pipe be used?
Simple circuit question for a novice mwfooshecpa Electrical 3 01-31-2011 03:54 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Simple question on strapping satz Building & Construction 8 11-27-2009 10:21 PM
Simple question on 16" O.C. framing TitaniumVT Building & Construction 10 11-27-2009 07:51 PM
Conduit, above ground, code question davewest Electrical 6 02-27-2008 04:55 PM
