Simple Closet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 09:34 AM   #1
novice
simple closet lighting
hello, this is my first post, my first home, and my first closet. I would like a simple diagram to hook up a light switch and light in a closet from an outlet already in the same wall. If this is possible i would like simple directions as I am good at following directions, but bad at reading between the lines. I can send pictures. I don't have alot of time so if there is no simple clear cut solution I will have to find another.
Thank You
theboss is offline   Reply With Quote
Old 02-16-2009, 09:42 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If you want simple, quick and low cost- http://www.pegasusassociates.com/led...osetlight.html this would be the way to go.
wirenut1110 is offline   Reply With Quote
Old 02-16-2009, 09:56 AM   #3
Licensed electrician
Rewards Points: 1,052
Closets have strict clearance requirements from storage areas and also the allowable fixture types. Incandescant fixtures need 12" clearence from the front edge of the shelf, fluorescents need 6". Ex, your shelf is 12" deep, the fixture edge would need to be at least 24" from the back wall to give youe the required 12" clearence.
Bare bulb incandescents are not allowed.
Old 02-16-2009, 10:49 AM   #4
novice
code?
thanks, but well, i wasn't exactly asking for the code. Was wondering if I can use the existing wiring to an outlet to create a switch and light fixture simply and quickly.
ps. don't codes vary from place to place?
Old 02-16-2009, 10:50 AM   #5
Assuming your place is wired in romex, your existing outlet will have a black and white wire (or a set of blacks and whites) and a bare ground wire.
Your new light will have black and white leads. For instructive purposes, the current runs thru the black lead, into the light bulb, thru the filiment and out the white.
From the existing outlet, you need to run a 2 wire cable, the same size as the existing (12 or 14 gauge), to a switch box and from there to a light box. The boxes will be single gang plastic "cut in" or "old work" boxes. They grip the drywall with built in fasteners.
In the existing outlet box, color to color, bare to bare.
In the switch box, connect white to white, bare to bare. Both blacks go to the switch terminals. The switch simply connects/disconnects the black (power) part of the circuit.
At the light box, color to color, bare to bare (or green).
220/221 is offline   Reply With Quote
Old 02-16-2009, 01:33 PM   #6
surrogate is offline   Reply With Quote
Old 02-16-2009, 07:22 PM   #7
Before someone told you how to install the wiring it would be prudent to know if you even are allowed to install the light.
There are local amemdments to the code, but it is called the national electrical code. Some areas adopt the latest editions at different times.
Old 02-16-2009, 09:55 PM   #8
Registered User
Termite's Avatar
It is safe to say that the bulk of the jurisdictions in the USA use the NEC code for electrical, and/or the IRC, which mirrors the NEC's requirements.
Old 02-16-2009, 09:56 PM   #9
Is it still allowed to have a bare bulb light?
Or is there just a distance requirement?
Simple Electrical Lighting Problem Neonimous Electrical 3 01-02-2009 02:46 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 09:36 PM
