Simple Circuit Question For A Novice - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 02:27 PM   #1
Likes to Build Stuff
Simple circuit question for a novice
I've done some wiring, but nothing too technical -- here's what I am after. I have tied into a wall outlet to power two lights by switch and another wall plug with a switch. This project is a built-in set of 2 study carrels for my kids.
So, the question is, can I run to everything (all 3 switches) somehow with one wire? I am using 12 guage (black, white, and ground) wire. Or, do I need to run off of the jump out of the wall plug 3 seperate wires to each light switch?
See, simple, huh? I'm just an accountant and try to do the best I can and remain safe -- but I don't want to use too much cable if I don't have to.
Thanks for your kind responses to a novice!
mwfooshecpa is offline   Reply With Quote
Old 01-31-2011, 02:34 PM   #2
Experienced
Jackofall1's Avatar
Welcome to the best DIY'r forum on the net.
I am confused with your explanation, you mention 2 switches, then 3 switches, where is all this wiring running? in the walls?
What is study carrels? some kind of desk?
Perhaps a picture, or a sketch drawing would be helpful
Mark
Old 01-31-2011, 02:41 PM   #3
Thank you for your reply! I don't have a sketch, but let me try and do a better job explaining.
Study carrels - two seperate study spaces (like walled-off desk areas) in a study.
My power source is one wall plug which I have tied into.
From that, I have a hard-wired light controlled by a switch, another hard-wired light controlled by a switch - both mounted to the two opposite sides of the seperator wall -- and one other wall plug which is to be controlled by a switch.
Can you do it with one pathway, or do I need to run 3 wires to each of the 3 things?
Thanks!
Old 01-31-2011, 02:54 PM   #4
Experienced
Jackofall1's Avatar
Where will the switches for the lights be mounted, not that it makes a difference. and is the switched plug already mounted? or is the plug being mounted out of the wall?
Well to answer your question yes it can be done from (1) power source, with (1) main wire with circuits parrallel to it.
Mark
Multi Wire Circuit Question BPC Electrical 24 04-22-2010 04:29 PM
Dryer circuit 4-wire question firemanpato Electrical 11 03-05-2010 05:44 PM
Wet Bar Circuit question Straightgrain Electrical 8 12-31-2009 08:11 AM
Yet another 3 way circuit question! sirkeen Electrical 4 07-28-2009 11:54 AM
Simple wall framing question.. jogr Building & Construction 7 10-28-2008 10:43 AM
