Siemens Sub Panel Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 12:15 PM   #1
siemens sub panel breaker box
i cannot figure how to wire the neutral and the ground wires in this box as there is only a neutral bar and not a grounding bar also as the main box has. there is also an option for abonding strap.please help,thanks,ron
ronbeany is offline   Reply With Quote
Old 11-19-2009, 12:23 PM   #2
I know on a main panel you can have neutral and ground wires in the same bus bar (not in the same hole for neutrals though) Not sure if the same applies to sub panels or not.
zedman is offline   Reply With Quote
Old 11-19-2009, 01:45 PM   #3
U dont use the bond strap on a sub fed panel .And your neturals and grounds have to be seprated . u need to get a ground bar
cdundon4va is offline   Reply With Quote
Old 11-20-2009, 05:55 PM   #4
Electrical Inspector
To separate the neutrals and grounds in a siemans panel remove the jumper between neutral and gronding bars.If this is a newer panel it would apear to be a copper wire in the upper part of the panel (below the main breaker if installed).In older style panels this would be a bar spaning the bars in the bottom of the panel.
Power Up is offline   Reply With Quote
Old 11-21-2009, 11:01 AM   #5
Rewards Points: 58
Search "sub panels" above and you will get all the required information you need. Promise.
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Can I legaly change out my breaker panel? Red Squirrel Electrical 6 08-24-2009 10:07 PM
Hot water flate rate conversion to breaker panel curlycord Electrical 1 05-06-2009 08:24 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
