Siemens LOGO - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 08:35 AM   #1
Siemens LOGO
Hi guys
I got an Siemens LOGO PLC
I want to program it to act like a timer
when input one is active relay 1 should active 5 sec after input one has activated
Can any one do this simple programing ?
quanchai is offline   Reply With Quote
Old 07-26-2012, 08:45 AM   #2
Master Electrician
Do you have the software to actually program it or just the plc?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-26-2012, 08:52 AM   #3
Yes i have the software
LOGO Comfort v7.0
but i dont know any thing about plc programing
Old 07-26-2012, 09:31 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,974
A bit complicated to explain here......
Basically you will set up one input to start the timer. When the timer times out, it sets the done bit which you then assign to an output to do something. Depending on the timer, most will automatically reset when the input condition is no longer true.
When you read the help section (you have done that...right?), you will see references to ladder logic and function blocks.
A typical ladder rung looks like this...
Whereas a function block looks like a block with input lines and one or more outputs.....
I'm an AB guy but based on the Siemens I have done....it will most likely be function block.
One key thing to remember....A PLC operates in a continous loop. Starts at the top...goes through the logic.....then goes right back to the top and starts over.
ddawg16 is online now   Reply With Quote
Old 07-26-2012, 09:46 AM   #5
Well i dont have any exp with PLC programing what do you suggest to start with ladder programing or block ?
Old 07-26-2012, 09:54 AM   #6
Master Electrician
No offense but this isn't going to work out for you. I've done plc courses and have a basic working knowledge. So knowing what little I do know it will be next to impossible for someone who knows them well to explain the someone who has never worked with them how to do what you want. Especially over the internet.
Old 07-26-2012, 09:56 AM   #7
can you programin it for me ?
Old 07-26-2012, 10:12 AM   #8
JOATMON
ddawg16's Avatar
Well....if were me, my company whore's me out at $175/hr. If I do stuff on the side, I get $100/hr.
Considering the cost of the PLC.....I'm not worth it.......I'm sure Andrew is not any cheaper.
You really need to sit down and go through the software. That paticular PLC is about as easy as you can get.....you just have to open up the program and start reading.
One thing that may help deciding if you do ladder vs function.....
Do you have any experience reading and/or troubleshooting machines that used relays? In the old days, machines used relays to control the sequencing. Hence, ladder logic was modeled after this.
If so...use ladder logic.
If not....then read up on function block.
Old 07-26-2012, 10:25 AM   #9
the Musigician
DangerMouse's Avatar
True..... That and the price of a round trip ticket to Iraq could be quite a bit.....
DM
Old 07-26-2012, 10:29 AM   #10
JOATMON
ddawg16's Avatar
DM
1st Class......but, I can provide my own vest and firepower....and don't forget the hazard pay.....
Old 07-26-2012, 03:49 PM   #11
wait a sec i am not in iraq this is just a proxy server i am using
Old 07-26-2012, 03:57 PM   #12
JOATMON
ddawg16's Avatar
What country are you in? And why is your ISP using a proxy server in Iraq?
And....does the proxy server have to kill itself if you send ****o through it?
Old 07-26-2012, 04:02 PM   #13
I am in sweden and its not the isp its just a proxy server
Old 07-26-2012, 04:05 PM   #14
So fo you guys recommend that i start to kick on with the block ore ladder
What is the diffrence difference them
Old 07-26-2012, 04:08 PM   #15
JOATMON
ddawg16's Avatar
Oh....in that case, a 1st class ticket to Sweden would be even better....
All joking aside....your just going to have to dig into the help and become a PLC expert.
The learning curve is pretty steep.....seems hard at first, but once you get through a couple of the basic steps....the pace picks up real fast.
Siemens Sub Panel Wiring drunkboating Electrical 9 04-04-2012 09:19 AM
Siemens Interlock Kit? kcrossley2 Electrical 4 09-08-2011 05:09 AM
Substituting a Murray for Siemens branch breaker mfreeland Electrical 14 12-04-2010 09:04 AM
siemens breaker /square d HOM teanne Electrical 4 01-26-2010 08:41 AM
