Siemens Load Center Help - Bonding - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 11:26 AM   #1
Hello,
I am wiring a new home in Vermont and I have the load center wired and installed. It is the main disconnect. I need to bond the ground and neutral and I am wondering how this is done in the panel. I didn't notice an easy way when I looked at the panel, nor do I know if the panel comes bonded or not. Any suggestions? It's a Siemens 200A load center with built-in 60A transfer switch.
Is it as easy as wiring the neutral/ground bars to the panel with a screw and section of stranded wire?
J
aquasport17 is offline   Reply With Quote
Old 10-24-2012, 12:03 PM   #2
From the following Siemens link...
"Pre-positioned bond screw makes bonding a snap."
http://w3.usa.siemens.com/powerdistr...adcenters.aspx
Did you read all the instructions which came with the load center, read the various labels pasted on the panel, etc.?
Do any of those mention a "bond screw"?
(When all else fails, read the instructions!)
Billy_Bob is offline   Reply With Quote
Old 10-24-2012, 12:10 PM   #3
Actually, the panel is OEM by Siemens, but it's marketed by gentran. It came ONLY with the gentran instructions for wiring the 60A generator feed, and for operating the transfer function. It had NO documentation on the panel itself.
I will take a closer look when I am up there this weekend working I guess.
It appears that it may not be as hard as I think. I am really wondering if it comes pre-bonded or not.
Old 10-24-2012, 12:20 PM   #4
I think I found it. Did some digging on their site and appears that if my panel is like the rest of their panels, There is an easy way.
Thanks for the help!
Old 10-24-2012, 12:21 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Most panels do not come prebonded, but have a green bond screw in a package somewhere.
The Following User Says Thank You to jbfan For This Useful Post:
jrclen (10-24-2012)
Main load center grounding question. sgip2000 Electrical 18 10-03-2012 12:45 PM
Boxing In My Load Center? ddawg16 Building & Construction 5 08-22-2012 11:21 PM
Looking for "Wrongs" in my Siemens load center Minus08 Electrical 31 01-11-2012 11:47 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 08:17 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
