Siemens Interlock ECSBPK09 Pic - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 03:30 PM   #1
Hi. Does anyone have the "Installed" picture of the ECSBKP09 Interlock kit? The Siemens catalog does not seem to show a clear picture of how it is "interlocked" between Main Breaker and the Generator Breaker.
khfactor is offline   Reply With Quote
Old 12-22-2012, 04:24 PM   #2
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Are you sure that is thr correct catalog number? I cannot find that number in my catalog or on the web.
HIVOLT is offline   Reply With Quote
Old 12-22-2012, 04:32 PM   #3
yes, I just double checked. ECSBPK09 is the correct part number. See the Siemens catalog. Page 1 - 24.
http://w3.usa.siemens.com/powerdistr...01-018-024.pdf
Old 12-22-2012, 05:32 PM   #4
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
I just cannot find a good photo or diagram to help you solve your problem.
Old 12-22-2012, 06:03 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I think this is the correct interlock
Old 12-26-2012, 06:36 PM   #6
Can this be used on a G4040MB1200 with vertical throw 4-pole 200A EQ9685 breaker? The Siemens Speedfax2011 catalog says no INTERLOCK Kit is available, but the configuration of this device looks the same as the EQ9685 breaker in the G4040MB1200 Load Center, no??
Generator / Interlock question khfactor Electrical 30 02-17-2013 07:35 AM
Help trying to identify Main Panel circuit breaker Interlock solution Linos Electrical 9 05-16-2012 04:00 PM
Siemens Interlock Kit? kcrossley2 Electrical 4 09-08-2011 05:09 AM
Substituting a Murray for Siemens branch breaker mfreeland Electrical 14 12-04-2010 09:04 AM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 03:44 PM
