Siemens G4040MB 1200 Load Center - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 03:37 PM   #1
Rewards Points: 89
Specing out my breaker costs for adding the following to my existing service.
1 X 2pole 30 amp for a heater
2 X 1pole 20 amp for new receptacles and bathroom
2 X 1pole 15 amp for lighting and saniflo pump
1 X 2pole 15 amp for bathroom heater
Am I correct in assuming this load center takes QP breakers (cover panel with specs on it is illegible from hack builder electrical work)
Also,since it is new service,but no new bedrooms,do I have to use AFCI breakers?
Any useful inputs will be greatly appreciated
P.S. I have lots of room for any size breakers I may need (size matters!)
spring3100 is offline   Reply With Quote
Old 05-11-2013, 04:14 PM   #2
Rewards Points: 746
QP breakers are correct.
Depending upon where you live and what code cycle you're on you may need an AFCI breaker for the lighting and receptacles. They're not just for bedrooms anymore.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
spring3100 (05-11-2013)
Old 05-12-2013, 07:18 AM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Am I correct in assuming this load center takes QP breakers (cover panel with specs on it is illegble form hack builder electrical work)
ususally if you run new circuits you need to put in ACFI breakers ..at least here the is the line in the sand.. and it depends also on what code cycle your area is on ?
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
spring3100 (05-12-2013)
Old 05-12-2013, 08:17 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
If you run new circuits, and those circuits require AFCI protection that that is your answer.
See what code cycles your area is under, but these days most are to a point where they are required. Remember, most, but not all, areas/circuits do require AFCI protection.
This is from the 2008 NEC:
(B) Dwelling Units. All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways, or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of the branch circuit.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Philly Master (05-12-2013), spring3100 (05-12-2013)
Old 05-12-2013, 08:32 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You can only put receptacles on the bathroom circuit if those receptacles are in the bathroom, unless the "bathroom" circuit only services lighting outlets.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Old 05-12-2013, 08:44 AM   #6
Rewards Points: 89
I have one dedicated 20 amp circuit for the bathroom,if you re-read my post you will see a total of six circuits,but thanks for your input
The Following User Says Thank You to spring3100 For This Useful Post:
Old 05-12-2013, 08:49 AM   #7
Rewards Points: 89
This quote mentions outlets,but doesn't reference lighting,will I need it on that circuit also?Thanks for your input
Old 05-12-2013, 09:06 AM   #8
k_buz's Avatar
"Outlets" does not mean what you think it means. When the code states "outlets"....
Outlet. A point on the wiring system at which current is
taken to supply utilization equipment.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
Philly Master (05-12-2013), Speedy Petey (05-12-2013), spring3100 (05-12-2013), stickboy1375 (10-31-2013)
Old 05-12-2013, 10:10 AM   #9
Rewards Points: 89
Thank you,and consider me educated!
Old 05-12-2013, 10:26 AM   #10
Rewards Points: 89
Just so we all on the same page,I will consider the need for 2 AFCI 20amp single pole breakers for the recepatcle circuit and the dedicated bathroom circuit and 2 AFCI 15amp single pole breakers for the Lighting circuit and the dedicated receptacle for the Saniflo pump.
The 15amp two pole 240V for the bathroom heater and the 30amp two pole 240v for the area heater doesn't need anything special,does it?
Thanks once again for all of your awesome inputs!!!
Old 05-12-2013, 10:28 AM   #11
Rewards Points: 166
I also have the Siemens G4040MB1200
Siemens G4040MB 1200 Load Center-100_4920.jpg   Siemens G4040MB 1200 Load Center-after-front.jpg   Siemens G4040MB 1200 Load Center-full-view-cover-off-2.jpg   Siemens G4040MB 1200 Load Center-top-panel.jpg   Siemens G4040MB 1200 Load Center-bottom-panel.jpg
Minus08 is offline   Reply With Quote
The Following User Says Thank You to Minus08 For This Useful Post:
Old 05-12-2013, 10:41 AM   #12
Rewards Points: 166
Heres a good decoding guide for model numbers for Siemens load centers
Old 05-12-2013, 11:10 AM   #13
Rewards Points: 150
an outlet can be a receptacle, light or even a smoke detector.
The NEC defines an Outlet as: A point on the wiring system at which current is taken to supply utilization equipment.
usair is offline   Reply With Quote
The Following User Says Thank You to usair For This Useful Post:
Old 05-12-2013, 11:29 AM   #14
Rewards Points: 746
240 volt circuits don't require AFCI protection - yet.
A dedicated bathroom circuit only needs GFCI protection, not AFCI.
The Saniflo pump recommends being on a GFCI protected circuit.
Basically, only your receptacle circuit and the lighting circuits likely need AFCI protection.
Check with your AHJ.
Old 10-31-2013, 04:03 PM   #15
Rewards Points: 89
Update to this post,Electrical inspector visited in August,said he would be satified with AFCI's on Lighting and Receptacle circuits,and considered the GFCI for bathroom and Saniflo pumps to be sufficient protection.
240 Volt heating circuits did not need AFCI or GFCI.
Thanks once again for everyones input.
Main load center grounding question. sgip2000 Electrical 18 10-03-2012 12:45 PM
Boxing In My Load Center? ddawg16 Building & Construction 5 08-22-2012 11:21 PM
50 amp 220 over 8/3 with ground to 40 amp double breaker feeding into load center? mgambino Electrical 45 06-05-2012 07:11 AM
Looking for "Wrongs" in my Siemens load center Minus08 Electrical 31 01-11-2012 11:47 PM
Expanding load center capacity in barn mn1247 Electrical 8 09-13-2011 09:24 AM
