Siemens Disconnect Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 01:18 AM   #1
I obtained a Siemens 30 Amp disconnect for a new water heater.
Installation is pretty straight forward, but I have a question about the neutral and ground connections.
The switch is being feed by a 30 Amp breaker in a subpanel where the neutral and ground are isolated. On the attached drawing(simplified for illustration purposes) The neutral and ground appear to land on the same aluminum block. There also appears to be a bonding screw.
What is the correct connection for this set up?
Randell Tarin is offline   Reply With Quote
Old 03-21-2008, 01:22 AM   #2
Rewards Points: 930
Usually a water heater has no neutral, it's fed with a 10/2 with ground, and the white is recoded black.
Also there is no reason to fuse the WH at the disconnect.
LawnGuyLandSparky is online now   Reply With Quote
Old 03-21-2008, 01:30 AM   #3
I would have preferred a non-fused disconnect, but it was free!
Would it make a difference?
Anyhow, I had some 10/3 left from another project, so I used that.
Please correct me if I'm wrong: what I'm understanding is that I just connect my two hots, in this case BLACK and RED to the LINE lugs and just tie-off the NEUTRAL and GROUND wires?
Old 03-21-2008, 01:51 AM   #4
Rewards Points: 2,350
Land the ground and cap the white. No need to use it here. Definitely don't parallel it with the ground.
InPhase277
Old 03-21-2008, 01:55 AM   #5
Thanks InPhase!
Does the bonding screw simply bond the GROUNDING BLOCK to the case?
If so, do I or do I not bond to the case? Or do I just remove the bonding screw.
Old 03-21-2008, 02:17 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If the box is metal I suspect the green screw bonds the aluminum block to the metal of the enclosure. Which you will need to to if it hasn't been done That small white circle at the end of the green screw may be the hole you use to bond the block to the enclosure can using the hole in the al block to guide the screw to a threaded hole in the metal of the enclosure. The drawing may just showing the screw held by that lug till used. This could be a disconnect intended for a 3 wire feeder. It was never intended for a ground wire but must have a bonding screw to bond the neutral to the metal for the intentional fault current path. Once you have installed the green bonding screw then you connect the electrode grounding conductor to the lug.
Old 03-21-2008, 02:19 AM   #7
Thanks for the replies guys.
Old 03-21-2008, 11:33 AM   #8
Hey Randell, I see you changed your avatar. Is that picture you, or General Lee on vacation?
InPhase277
Old 03-21-2008, 01:17 PM   #9
InPhase277
Suh, I am the reincarnation of Lee. Don't you see the resemblance?
Old 03-21-2008, 09:23 PM   #10
Cow
No reason for a disconnect when you can install a simple breaker lockout for very cheap.
Cow is offline   Reply With Quote
Old 03-21-2008, 09:27 PM   #11
I want to connect a 15A 240V 7HP compressor with a 60' run from the box. What size wire should I use?
nonotoriani is offline   Reply With Quote
Old 03-22-2008, 12:40 AM   #12
UAW SKILLED TRADES
Stubbie's Avatar
It is not possible for a 7 hp compressor at 240 volts to be only 15 amps.
Old 03-23-2008, 03:22 PM   #13
Yeah, I know. It's more for convenience. This water heater is for some guest cabins. Because of the high mineral content of our well water, we've found it necessary to drain our hot water heaters when they're not in use. A nearby shutoff saves me quite a few steps. I'm all for saving money, but I want to save my arthritic knees too.
subpanel question Brik Electrical 2 11-30-2008 06:31 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 08:43 AM
fused disconnect and/or GFCI ? pchiz Electrical 8 12-21-2007 11:02 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
