Shut Main Breaker Off: Meter Flywheel Still Keeps Slowly Turning - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2009, 03:20 PM   #1
Shut Main Breaker Off: Meter flywheel still keeps slowly turning
We've been having some odd electrical issues over the last month (see my post earlier today), but this seems something more clear and easily answerable:
When I shut off my main breaker, my meter's flywheel continues to turn . . . slowly, but distinctly. It's been fifteen minutes, and the flywheel is still slowly turning.
What does this tell you about the wiring and grounding in my house?
~j
story is offline   Reply With Quote
Old 09-16-2009, 03:39 PM   #2
http://en.wikipedia.org/wiki/Electricity_meter
Check out the section called
Reading electromechanical meters
Old 09-16-2009, 04:20 PM   #3
Licensed Pro
~j
You may have a high resistance contact between one of the hot legs and the neutral or ground. Since this may be in the meter enclosure, you should contact your utility company and a licensed electrician. This does not sound like a DIY fixable problem.
Old 09-16-2009, 05:22 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Yoyizit had the answer:
Quote from Wikipedia : Electricity meter
Electromechanical accuracy
In an induction type meter, creep is a phenomenon that can adversely affect accuracy, that occurs when the meter disc rotates continuously with potential applied and the load terminals open circuited. A test for error due to creep is called a creep test.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-16-2009, 06:07 PM   #5
Rewards Points: 1,418
Such a high resistance contact could be due to capacitance, the hot and neutral wires running some distance juxtaposed with "just" the plastic wire insulation between them. This current flow is sometimes referred to as phantom current in other contexts such as when measuring voltage on a supposedly dead circuit wire while using a digital meter which is typically more sensitive than an analog (needle) meter.
Old 09-16-2009, 07:40 PM   #6
joed's Avatar
Rewards Points: 11,590
Or you have a second panel tapped off the meter. This could possibly be timer controlled panel that gives alower rate because it is only on at low power times. Typically used for water heaters.
Old 09-17-2009, 09:16 AM   #7
Journeyman Wireman
Rewards Points: 150
The OP doesn't say where they live, but in some Portland, OR homes I occasionally see an old 2-wire circuit tapped from the meter. The hot is under one of the meter lugs and exits the weather head, the neutral is split bolted on the neutral of the poco drop. Those unfused wires are then ran on porcelain knobs on the exterior of the house to a fuse box or feeds the garage. This set up would by pass the main breaker. Just demo'd and re-fed a run like this yesterday.
Jupe Blue is offline   Reply With Quote
Old 09-17-2009, 11:31 AM   #8
There are sub-boxes in the house, but they've been disabled in the rehab. As far as I can tell, the reason for the flywheel still turning would be either 1) "creep" -- which I think is unlikely, since it was so prolonged. Or, 2) the water main for the house is inside, and it appears to be wired pre-breaker box. So, the water meter, requiring some power to run, is the likely cause.
Now, I still have a 2007 kWh energy consumption from the last thirty days to figure out, and a few more odds and ends. But the forum is helping tremendously, for me to get the info I need to understand my house and its electrical set-up.
I will call the energy company, and possibly an electrician, soon . . . but for now I'm very carefully gaining an education on the possible problems.
Thanks,
~j
Old 09-17-2009, 11:46 AM   #9
Tool Geek
PaliBob's Avatar
Thanks for the feedback. You are on the right track in investigating leads.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-17-2009, 12:04 PM   #10
Use your wattmeter as an ammeter. 1800 w over a 14 second period is 1800w/240V = 7.5A, average, over that same period.
Switch appliances on and off to see where the current is going.
2007 kwh/[720 hr/mon] = 2.8 kw all the time. Avg is ~1 kw.
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
100amps meter with 200amp breaker box? Snooker Electrical 3 04-15-2007 02:39 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
