Shower Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 07:19 AM   #1
Next Time...New Build
Rewards Points: 150
Shower Lights
Hey guys. Are there can lights that are specifically rated for installation inside a shower?
A friend has a light in the stand up shower that once the shower is run, there will be a crackling coming from it and the bulb will flicker. I am guessing it is from the steam within the shower. There is an exhaust fan outside of the shower which is running, but the light will still do that.
So, I wanted to see if there would be a can designed for a moisture area that I could install.
Thanks in advance.
RickyBobby is offline   Reply With Quote
Old 01-10-2011, 07:36 AM   #2
Not that i know of, its just the shower trim kit that you need.
baum is offline   Reply With Quote
Old 01-10-2011, 07:44 AM   #3
Rewards Points: 150
Thanks Baum. The trim kit probably has some type of gasket to keep the moisture out?
Thanks a lot for your help. I will have to check and see if that is in there.
Old 01-10-2011, 07:45 AM   #4
Yes it does
Old 01-10-2011, 10:12 AM   #5
Chicago, IL
Michael Thomas's Avatar
This question of how to apply the NEC to lighting above tubs and showers is is endlessly debated on Electrical Contractor and Home Inspection boards.
The general consensus is that if the lowest point of the ceiling in the tub/shower zone is 8' above shower threshold or flood rim of tub equipment must be damp location rated at a minimum.
Where things get complicated is that per the NEC lighting must be rated for wet locations if it is subjected to wet zone conditions. Most HI's I know agree that (for example) a sauna or "steam shower" meets these conditions. Some believe that if the lighting is possibly subjected to water spray (for example, if some types of non-fixed-potion spray heads or wands are installed) the lighting is in a "wet-zone" as well.
The only definitive answer to these questions is the one you get from your local building department or some other AHJ. And the only why to find out is to ask them.
Once you know what is required, you can then buy lighting fixtures listed by the manufacturer for a damp or wet location, as needed to meet the requirements.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Installing more than One shower Head tinker67501 Plumbing 4 09-01-2010 11:53 AM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 07:43 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 12:26 PM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 04:08 PM
